Results 1 to 6 of 6
Thread: Welcome Momus Builders
    Sep 2010
    Hello Momus Builders and other Interested Parties
    We have requested and been granted a new Sub Forum within the DIY-CNC Router Table Machines forum. I encourage all future discussion on the Momus machine be posted under this sub forum.
    Hopefully we are able to build off the solid interaction amongst the builders who are at various stages of their build and those who are interested in starting a build.
    Thanks to "iplay1515" for posting the initial thread found here
    http://www.cnczone.com/forums/diy-cn...cnc_plans.html
    which got us started and of course to Bob for a great set of plans to build this top notch CNC router table.
    Cheers, Dave
    May 2010
    Cool, thanks!
    The MOMUS is a great design and this should be an active sub-forum.
    Regards,
    Randy
    Jul 2007
    New Zealand
    Momus forum
    Hi all . Its great that we have a thread just for Momus. there is certainly a lot of activity with many building.
    I have just started a new one here in NZ and have been busy converting to what we can get locally which is almost all metric.
    Have got Keling 380 oz steppers, Geko 540 (from Aussie), belts pulleys etc. from hubbard, abec7S FROM Northbridge US. etc.
    Rails are stainless 40 mm and 65 mm so hole centres for ABEC7 bearings require opening out by~ 2mm.
    Main "z" beam unavailable in Aluminium unless I buy 5 metres so have settled for steel RHS which I plan to put lightening holes in and fill with foam to keep out dust. Size planned is 24"long working X axis with standard width.
    Have decided to set up with right and left hand rails at 40 mm, there does not look to be a problem with that approach.
    Have been looking at CamBam and have Autocad.
    Will post a few pics when things get going.
    Rayna
    Hamilton NZ
    Registered bwentzel3's Avatar
    Dec 2010
    a home for MOMUS
    It's great not having to search the whole forum for Momus info. Almost done the build, just the cover left to do. I need to relearn g-code also after a 21 year break. Bye the way, why MOMUS?
    thanks for the great design Bob,
    bill
    Apr 2011
    Quote Originally Posted by bwentzel3 View Post
    bill
    Don't worry, I was in same boat as you except mine was an 18 year break. I was cutting parts within a day since creating gcode is a lot easier now then it was in the early 90s. Tons of programs that do the work for you now with minimal hand editing.
    billj
    Apr 2011
    united states
    Dimension's verification
    Hello Group and Bob,
    I've been working on my build for some time now.
    I've completed the wood portion and have been working on the aluminum parts.
    I've been following the forum and have notice some dimension errors mentioned and have taken note of them.
    I am currently working on part number #19, page 52. The material list is .1875 x 2.5 inches, The layout dimension is 2.25 inches. Am I to trim down the 2.5 inch side to 2.25 inches? Or could this be an over site?
    Thanks for your support
    jerrywi
    1. Momus Design CNC Plans
      By iplay1515 in forum DIY CNC Router Table Machines
      Last Post: 09-27-2011, 12:46 PM
    2. UK Builders
      By visualbyte in forum DIY CNC Router Table Machines
      Last Post: 02-05-2008, 03:25 PM
    3. AWJ builders
      By Perp in forum General Waterjet
      Last Post: 01-02-2007, 02:33 PM
    4. CNC Builders Creed
      By ynneb in forum CNCzone Club House
      Last Post: 03-12-2004, 12:06 PM
