- any ideas for double mounts?
Re: any ideas for double mounts?
i had come up with these, but my machine messed up while i was cutting them, so I'm missing the top mount for the 300w spindle. the bottom stays on and has the lip for the ridgid and the spindle goes all the way thru. then i just have to remove the top mount to change between them. they're a tight fit, but once on they seem to hold , although the mdf does start coming apart when tightening to the gantry. I was going to cut them out of aluminum, but i'll try some hdpe first and see how that goes, once i get my machine going again that is.
- You may not post replies
- You may not edit your posts
Forum Rules
