- New Machine Build- Momus V3 Plans / upgrades to V2?
Hello all,
I have the Momus V2 planset, and was about to start construction, when I noticed a reference to a V3, and a further reference to the inclusion of thrust washers on the Z axis design. Is the release of a V3 imminent, and can I get specific information on the thrust washer implementation so that I may incorporate it into my build? I would hate to complete the machine and then see significant upgrades released
I will be doing a fair amount of aluminum milling, and plastic milling. No woodwork to speak of. I intend to build to the original plan dimensions, but would be interested in either forced air cooling or a mister system,
I already have the complete electronics, including the Gecko drivers / computer / steppers / power supply and all the small bits.
Any help will be greatly appreciated.
Thanks,
Craig
Houston, Texas
Re: Momus V3 Plans / upgrades to V2?
OK I found the thrust washer info in the addendum on my plans....:P, but does anyone have info on a V3 release?
I've seen no information about a V3 unit.
Bob hasn't updated the webpage in a while.
-=Doug
- You may not post replies
- You may not edit your posts
Forum Rules
