I've been following this thread for awhile as I plan to use some of your ideas when I build my momus.
Reading the comments and looking at the build of your cat shelves I think your approaching the build the wrong way. I do a lot of wood working, and although your approach is a sound one there are a few flaws. Like others have mentioned your spending a lot of time on making the glue up and then sanding. I think you would be better off, and much cheaper materials wise, if you were to do a bent lamination style glue up (If your not familiar here's a pretty good step by step of what it is http://www.wwgoa.com/replacing-a-bent-lamination/). If you read through the article you'll notice one point where he discusses spring back. Which is something you don't want. So rather than using solid wood which will spring back use bending plywood (Google it every company has their own name for their product). Using 6 pieces of 1/8" bending ply and a long open time glue will allow you to make your bases in about 15 min. Cut a solid piece to edge it with.
You would make a bunch of forms, put your bent laminations in them, and and put them in a vacuum press (Do-It-Yourself Vacuum Veneer Press). The next day take them out, put them on a vacuum platform in the cnc to trim to size, once all trimmed, put them on their side in another jig in the cnc to cut the mounting holes etc. Glue on the edge piece(s), and put on your finish.
One big advantage of the bending ply would be almost no sanding, once over with 220 and your done.
Your longest step should be finishing, which always makes or breaks a project. By using the bending forms you can also add a piece of showy veneer which could expand your product line, and make the shelves even fancier (I.E. you can charge more $$$$). You should have less than a total of an hour of labor in each of these.
Your also paying to much for the wood, in my area the poplar is about $1.25 a bf or less, for a 12" x 8' long piece it's $10. If you need it surfaced it's $.10 to $.15, a lineal foot. If you don't know of anyplace that sells to woodworkers let me know your state/city and I'll contact my network of liars and thieves and see if I can find you a local supplier that will sell you wood at a reasonable price.
Hope I didn't come across rude, I think you have a great idea and a neat product, and I hope you make a killing with them.
