Results 1 to 2 of 2
Thread: Meldas Replacing Spindle Drive
    Registered Jack2012's Avatar
    Apr 2012
    UK
    Hi
    New on here but an old hand at CNC (40Yrs). Faulty spindle (MDS-B-SPJ2-75) drive on XYZ Machine fitted with Mitsubishi control. Have sourced another spindle drive but unsure about loading parameters. I will not be able to upload parameters from old drive , as it probably wont power up. According to some documentation I have there should be a backup of the parameters in the control and should be downloaded to the drive on power up.
    Do the parameters load automaticaly or is there a procedure to do this.
    Any help on this would be appreciated
    Jack2012
    Jan 2011
    Is that a 700 control?
    It is possible that the previous user has put the backup on the hard drive. I have the instructions for NC backup as well as PLC backup and restore. For NC restore, I would guess you reverse A and B, not sure though. Gimme your email if you need it.
    Cheers.
  1. Replacing Fanuc AC Spindle Drive
    By barchdesigns in forum Fanuc
    Last Post: 04-22-2012, 01:35 PM
  2. Need Help!- Replacing a Floppy drive on Fadal VMC 8030?
    By ColinBC in forum Fadal
    Last Post: 01-24-2012, 03:28 PM
  3. Problem- 1986 qt10 getting rid of hi/low unit and replacing spindle drive
    By carbidecraters in forum General Metal Working Machines
    Last Post: 03-15-2009, 06:10 PM
  4. Tuning Bosch Drive cards when replacing SEM Motor
    By RMARCH in forum Bridgeport and Hardinge Mills
    Last Post: 03-03-2006, 12:34 PM
  5. Replacing Floppy Drive on Machine Controls
    By ObrienDave in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 07-31-2005, 09:29 PM
