Results 1 to 4 of 4
Thread: Helpn for SSS funtion and HPCC Funtion on M720
    Apr 2012
    indonesia
    Hallo..
    can somebody help me how to switch on the SSS function and HPCC function on M720.
    Thx before
    Jan 2011
    SSS (super smooth surface) is generally an option on the 720's, but if
    you have this option, you simply need to set parameter #8090 to 1
    I'm not sure to what HPCC refers to, but if it has anything to do with
    High Speed Hig accuracy, these are also options
    HSHA can be G05 P10000 (or G05 P2) depending on params
    Apr 2012
    indonesia
    yupzz..oke thx..i had done and for M720 there are have 2 way
    1. G5 P1/P2 it was for SSS
    2. G43
    G100 Q4(can chosse Q1 until Q9)
    G5.1 Q1
    explaination for
    -Q1 until Q3 is for Velocity (rough)
    - Q4 until Q6 is for precison it sam with G5 P10000 or P2
    - Q7 until Q9 for smooth
    Jan 2011
    With G5.1 Q1 - the "1" with the Q is not an argument
    that can be set (i.e. there is no G5.1 Q2).
    In your example there is a G100 in line 3. This is not
    a Mitsubishi G code, it might be something developed by your
    Machine Builder, or a user G-Code Macro.
    I would recommend ensuring parameter 1267.1 = 1
    and using G05P10000
    When 1267.1 = 0 you can use G05 P1, and G05 P2
    When 1267.1 = 1 you can use G5.1 Q1 and G05P10000
    G05P10000 is the way to go. It will give you the fastest possible
    thru put.
    There are a number of user parameters that control a variety
    of HS/HA functions.
    You can see these parameters under SETUP kardkey -> USER softkey
    then Hi-Prec Params
  1. PROBLEM WITH G41 FUNTION ON DECKEL FMAP
    By IlFincoITA in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-12-2012, 06:52 PM
  2. G54.2 Dynamic Fixture offset funtion (30i)
    By KBLANKE in forum Fanuc
    Last Post: 06-17-2009, 09:22 PM
  3. how do you use the fixture offset funtion
    By cob in forum Mastercam
    Last Post: 11-19-2008, 12:48 AM
  4. Replies: 4
    Last Post: 05-03-2007, 08:53 AM
  5. Extra steps using pocket funtion
    By timmyb199 in forum Vectric
    Last Post: 02-25-2007, 03:31 PM
