Results 1 to 5 of 5
Thread: G76 Thread problem on Mitubishi 700 control
    Jul 2009
    I get error P204 after the first line below:
    G76P010160
    G76x.4782z-.9P0307Q0140F.05
    any ideas?
    Jan 2011
    I'm guessing you're trying to thread on a lathe.
    You might try the second 2 digits in your first P command to be 00, and
    add your Q and R to the first line as well.
    Check where your start is in X and make sure the X is advanced in the correct direction.
    To amke a 1/2 x 13 thread you might do it this way as an example
    g97 g95
    s500m3
    g0g54x.6 z.1
    x.5
    g76 p030060 q.03 r.02
    g76 x .421 z-1.0 r0. p.0395 q.1 f.0769
    g0 x1.0
    Jan 2011
    I hit post before finishing the response below.
    if you still get an error, you can check parameter #1265.1 and if it is
    set to 1, then the G76 would be done in one line:
    G76 x z i k d f a q
    where the values you provide here would be
    x = finish location
    z= finish location
    i = radius at thread section (probably 0 for you)
    k = thread height
    d = first pass cut amount
    f feedrate
    a = thread angle
    q = start angle of thread
    number of finish passes parameter 8058
    finish allowance parameter 8057
    Jan 2005
    The "P" and "Q" need a decimal value on that control, as camsys has shown.
    Jan 2005
    On the SECOND "G76" line that is. And CAPITAL letters.
    1. Mitubishi Dwc90c Error 500
      By CHAD in forum General Waterjet
      Last Post: 06-11-2012, 09:48 AM
    2. Control Comparison Thread
      By datac in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-28-2012, 11:44 PM
    3. Mitubishi FX-10 chiller problems
      By sweet16 in forum General Waterjet
      Last Post: 01-12-2012, 10:07 AM
    4. Need Help!- G76 thread on Fanuc oi-t control
      By taz345 in forum Fanuc
      Last Post: 03-16-2009, 08:23 PM
    5. Thread commands on 6T control
      By Ricardo Guedes in forum Fanuc
      Last Post: 02-03-2006, 01:21 AM
