Does the machine have a Mits control?
Tool changes and carousel operations are done thru the PLC and
its ladder.
Are you getting an alarm on the control? If so what does it say
A likely cause is that there's probably some type of sensor that
reads from the tool carousel and if operationg normally would send a signal to
the PLC that it found the selected tool station. If the sensor is bad, or there
are other problems with the ATC, the machine would behave as you described.
How did you do the tool change?
LinkBack URL
About LinkBacks
