Meldas 500 series Drip Feed DNC ONE P460 Tape I/O Error with pictures
So we have recently moved onto high speed machining toolpaths and we've quickly found out the limiitations of our machines are memory capacity. We have just purchased a DNC ONE box via rs232 and are attempting to use it on our Takumi V8a mill with Meldas 500 (520AMR?) controls. The drip feed works fantastic when it works which is inconsistent because sometimes it will run 10% of the program and sometimes 60%, however we are running into a P460 Tape I/O Error.
DNC ONE Defaults are Data Bits: 7 Parity: Even Stop Bits: 2 Baud rate: 9600 I'm not sure on the pinout of the cable however I can test that in the meantime.
I'm not too sure how to check all the settings on the mill but I know the baud rate is 9600.
We are concerned with the error as well as the ability to press the cycle hold button and then resume the program at any time to be able to prove out programs and to double check clearances.
Could the error be caused by pressing the cycle hold button while running in tape mode?
My knowledge on the software communications is not great however I will provide as much info as I can find! Thanks!
P.S. I have attached some photos if that is of any help to anyone
Re: Meldas 500 series Drip Feed DNC ONE P460 Tape I/O Error with pictures
Found out that regardless of pressing the cycle pause button the same error occurs. I've seen some people mention that the device was trying to send in data to quickly and even if that is the case, I'm not sure how I would go about changing that with the DNC ONE Box. If anyone has any experience with these boxes let me know!
If there is no way to get this particular setup working does anyone have any suggestions on a DNC software that they've had success with on the Meldas Controller?
I drip feed my 520AMR using predator editor.
I use 9600 baud rate and rarely have any errors dripfeeding large 3d files.
9600baud Parity even Data 7 Stop Bits 2
I use an 2ms linesend delay and that seems to allow the buffer to stay happy but In case of the error you had before you might have to increase this delay. It's a bit of trial / error to fine tune your particular set-up.
I have drip-fed files while running cad, and surfing at the same time on this pc with no hiccups.
I installed a PCI dual comport in my PC and I feed my files through the rs232 comport.
