We are trying to set up a Mitsu M 50 controller for drip feed. Using Cimco 7 we able to bring files in using a computer with a RS 232 port. We go to diag in/out and hit "1" then send info from Cimco 7. Then have to type in file name and enter for it to run. Most files have been small up to this point. We tested a file with around 2500 lines of code. When bringing in the file it stops on the 1200 or so line and says not enough memory. Do we need to set things up differently ? Also figured on the smaller files we should be able to hit the start button after program is loaded but we have to select the file every time when in "memory" mode. Also tried using "tape" mode. Any help would be greatly appreciated. Thanks in advance.
