Need Help! mitsubishi meldas 320 spindle motor parameter help Mitsubishi AC spindle SJ-N 5.5k
Results 1 to 2 of 2
Thread: mitsubishi meldas 320 spindle motor parameter help Mitsubishi AC spindle SJ-N 5.5k
    Member geobuild's Avatar
    Nov 2012
    budapest
    Question mitsubishi meldas 320 spindle motor parameter help Mitsubishi AC spindle SJ-N 5.5k
    Hi
    I need help with the parameters of the spindle motor and encoder.
    I replaced the controller to a NCT ethercat and need to set the parameters to the ethercat Asyn drive.
    I have the original parameter disk but I guess it is in cp/m and I can!t read it maybe it is damaged.
    Does someone have the parameters for this ac spindle motor?
    what is the resolution of the encoder on it?
    thank you for the help
    Dec 2015
    Default Re: mitsubishi meldas 320 spindle motor parameter help Mitsubishi AC spindle SJ-N 5.5
    What is yours machine???
