I took the chuck off and just mounted the adapter plate and still have the vibrations. By tapping on the plate while monitoring the test indicator as I mount it I can get it pretty well centered with run out less than a couple thousands but I still have vibrations when running with just the adapter plate. When I take the plate off the machine purrs nicely and there is almost no run out noticeable on the original spindle.
Has anybody swapped to a four inch 3 jaw chuck on their 7x lathe? What was your experience?
LinkBack URL
About LinkBacks
