Results 1 to 2 of 2
Thread: Removing Cross Slide Dial
    Jun 2008
    I'm starting a CNC retrofit of my Speedway mini lathe. I began the process of stripping off all the unnecessary stuff, which went smoothly, till I came to the cross slide. I can't figure out how to get the indicator dial off to get to the screws that I assume are behind it. Doesn't this just pull off? Is there some trick I'm missing?
    Jun 2008
    OK, I figured it out. I took a small, thin blade jeweler's screwdriver and tapped lightly between the dial and the back mount and it began to separate nicely. From there I could work it loose with progressively larger blades. It's just a darn good spring that hold that thing on!
  1. 9X20 cross slide help
    By bearwen in forum Mini Lathe
    Last Post: 01-14-2010, 09:07 PM
  2. Metal for cross slide
    By arizonavideo in forum General Metalwork Discussion
    Last Post: 11-25-2009, 05:37 PM
  3. Cross slide wiggles
    By pzzamakr1980 in forum Mini Lathe
    Last Post: 01-13-2008, 06:38 PM
  4. cross slide
    By nantz in forum Benchtop Machines
    Last Post: 07-12-2006, 07:09 PM
  5. Cross Slide Lubrication
    By sp00k1e in forum General Metal Working Machines
    Last Post: 02-12-2004, 06:05 PM
