My guess from the info provided is that you have a fast blow, 4 amp, 250 volt fuse. One could insert an amp meter and measure what is being used to give a better view of what is happening in the circuit. Not sure the logic of why you would replace a 4 amp fuse with a 3 amp fuse and expect it not to blow.
LinkBack URL
About LinkBacks
