Hi johnn-e
You should be able to ajust the tail stock on your lathe to get this at .000 or closer than what you have, there will be 2 screws one on each side of the tail stock near the bottom, put a indicator on the barrel of the tail stock loosen one screw (just slighty) & tighten the other untill you get it moved on the indicator the amount you need, every time you move the tail stock you will most likely will have to ajust it, if you don't have a indicator then you will move it a little & take a cut, untill you get it right
LinkBack URL
About LinkBacks
