i'm not sure either have'nt removed mine, but i am going to in a day or so.
When i do i can take pics for ya..
bill
Has anyone removed the spindle from a HF 8X12? I tried to take mine apart to make sure the bearings are properly greased but after removing the chuck (just to make it lighter, I know it doesn't come off that way) and the pulley side stuff, I wasn't able to get the spindle to budge with medium blows with a dead blow plastic hammer or even moderate taps with a steel hammer and block of wood. I wasn't going get too crazy or do damage, so I gave up and was only able to add some extra grease to the pulley side since i could actually see the tapered bearing on that side. I'm wondering if it is pressed into place and requires the head stock to be removed and placed in a press to service the bearings? I can do this but I won't until the bearings need to be replaced if that is the method for removal.
bill
On my 7x12 I had to use a press to remove the bearings.
Regards,
Mark
www.wrathall.com
On the Yahoo forum for Lathemaster someone mentioned using a 4" PVC coupler and a threaded rod. He didn't get in to details, but it doesn't seem it would be that hard to figure out.
And, a lot cheaper than a press. ;-)
Okay,
Press required... I figured that. Now then, the threaded stock and coupler to fit over the chuck end is a good idea! Makes it possible to remove without disassembly of the head stock to put into the press! I have access to a press but was dreading the need tear down to get it there. Looks like I may go back in there and try that. I had given up the idea and was going to wait until it needed new bearings.
That should get the spindle out. I've used similar methods when working on cars.. never on my lathe (yet) but that should get the spindle free.
Most auto shops will probably press the bearing off for free if you ask nice... I know we used to do it all the time. (Pep Boys)
You could probably hand pack the bearing in place too. Gooey, messy... but kind of fun in a mud-pie kinda way. ;-P
