Results 1 to 3 of 3
Thread: 7 X 12 CNC Lathe conversion
    Registered fragger6662000's Avatar
    Mar 2005
    UK
    Hi
    I am looking at converting a conquest (C2) lathe 7 X 12.
    This will be my second conversion as i have converted a X1 long table.
    I want to utilize the same cnc control box and wonder if 200oz steppers would be enough?
    I was thinking of using a belt drive to increase the torque an tips on what ratio?
    I am also thinking of using the standard lead screws on both axes to start with.
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    I have had my 7X12 CNC running with 187 OzIn Unipolar Vexta PK268-02A's in half-winding Bipolar mode for years. I finally replaced the Z motor with a 287 Bipolar Keling motor. About doubled the rapid to 1600 mm/min (although I have some sort of interference problem I recently discovered and a losing the occasional step, so I have halved the rapids for now, with reduced the problem about 10X.)
    Mine has 2:1 belt reductions on both Axis. I did this more to avoid alignment hassles than for increased torque though. I really like having the X motor tuck under out of the way.
    The swarf guard on Z and the enclosure are a real benefit for a CNC.
    I replaced everything above the saddle. The stock X set up seriously limits the cross slide travel.
    I wanted to fit a ball screw on X (zero backlash is more important on X than on Z), but haven't installed the little Roton screw I bought due lack of space under the cross slide for pair of nuts and anti backlash widget.
    The cross slide currently has a 10x3mm trapezoid screw with two nuts, which I regularly need to adjust. Originally I put a 15x4 trapezoid screw with a Nylatron on Z. It now has a roton cheap rolled ball screw with a single nut. This was no real improvement over the Trapezoid set up.
    I won't do any further upgrades to this lathe, as it is simply too small and flexible. The only reason I got it is lack of space. Still it has done good service and acted as a lathe, mill, drill press, bore grinder etc.
    http://www.wrathall.com/Interests/interests_index.htm
    Take some time to set up/ repair the tail stock. They are truly crap on these lathes!
    I burnt out my original DC motor and have a 1HP motor with VFD driving it now.
    Attached Thumbnails Attached Thumbnails 7 X 12 CNC Lathe conversion-img_5698_1small.jpg   7 X 12 CNC Lathe conversion-img_5706small.jpg   7 X 12 CNC Lathe conversion-img_5707small.jpg   7 X 12 CNC Lathe conversion-img_5708small.jpg
    Regards,
    Mark
    www.wrathall.com
    Mar 2005
    UK
    cheers for the info.
  1. DIY Lathe Conversion?
    By Hdale85 in forum DIY CNC Router Table Machines
    Last Post: 09-28-2009, 02:43 AM
  2. Anyone done a C6 lathe conversion
    By mcraig79 in forum Mini Lathe
    Last Post: 11-13-2008, 05:38 PM
  3. My CNC Lathe Conversion
    By acondit in forum Videos
    Last Post: 10-17-2008, 11:20 PM
  4. Lathe VFD conversion
    By GMill7 in forum General Electronics Discussion
    Last Post: 03-28-2008, 05:36 AM
  5. CNC lathe conversion (again, sorry!)
    By kong in forum General Metal Working Machines
    Last Post: 03-27-2004, 02:06 PM
