Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: cnc newb wanting to convert HF 7x10
    Oct 2009
    I bought a HF 7x10 mini lathe earlier this year and use it for all kinds of stuff. I cut everything from polyurethane to titanium on it and have had good results.
    I'm an automotive machinist by trade, and i'm wanting to mess around with different shapes of valve heads that will work good with my porting... but to do this I realy need to convert to cnc. I will need to be able to do dynamic radii on the valve heads (starts out as a certain size radius and gradually changes to one of a different size in the same cut) and undercut the stems at the head. No way I'm going to be able to do this manually. Take a look at this picture of a valve and you will see what I'm talking about. the plan is to use a section of delrin rod to make a valve with test profiles and see how they react on the flowbench, and once I have found my ideal profile start to cut them into actual valve blanks to build the heads with.
    I am apt enough to get the mechanical part of my cnc conversion down, but I'm pretty much clueless as to the electrical/control part of it. I've been reading these forums for a few weeks and have picked up alot of good info, but am still too "green" to really go anywhere with it. I don't know what my ideal setup would need. I need it to be robust enough to machine stainless and titanium and the like. I've got a ballscrew setup laid out for the Z and X axis.
    I'm having trouble completely grasping the meaning of the following: steppers, servos, dual shaft, bipolar, gecko, timing belt vs. direct drive, among others. My learning curve is steep once I get the basics figured out, but the basics are where I am having problems.
    Basically, what kind of motors, drive, and control do I need ?
    Thanks for any advice/help.
    Registered RotarySMP's Avatar
    Mar 2004
    Vienna, Austria
    Hi Defrag010,
    I did my 7x12 a few years ago.
    http://www.wrathall.com/Interests/interests_index.htm
    For the controls I would recommend you use
    2x Gecko G251 (these were not made back when I did mine)
    1x Keling KL- 4875 Power supply
    2x Keling KL23H276-30-4A
    1x Keling C10 breakout board.
    You could probably fit all that into the space left by the Gear train.
    If you buy a Homann speed controller, you can also control the spindle from the CNC software.
    You can get break out boards from lots of vendors, also Vexta motors could be used, and a PSU you can make yourself, so I have just used Keling as an example here. This stuff is pretty cheap, so rather than mucking around trying to save the last couple of bucks, making one order with an outfit like Keling will probably save you a bunch of time.
    For software, I use TurboCNC as I am running it on an ancient Pentium laptop. If you have space for a desktop PC, then Mach 3 seems to be the most popular control software. EMC also has a strong fan club, but will need a bit more computor skill to set up.
    Regards,
    Mark
    www.wrathall.com
    Oct 2009
    Thanks!! That's exactly the kind of information I have been looking for!
    That spindle speed controller sounds Great. Which model would work with my mini lathe? there are a bunch to choose from on their website but I have no clue which one would work for me. Is there a way to wire one of those up to where I could still use the spindle speed pot to manually control the spindle if I was doing something manually?
    I forgot to ask about limit switches also.. I understand their purpose, but where do they fit into the grand scheme of the conversion?
    Mar 2004
    Vienna, Austria
    I don't have limit switches on my mini lathe. These low power steppers will simple stall in the case of a hard crash, they don't have the torque to strip a ball screw.
    As I use my lathe for all purpose hobby engineering, I am constantly swapping between the three jaw chuck, the four jaw independant, the face plate, the ER-32 collet chuck, etc so a limit switch would need to be adjustable for all these different -Z limit positions.
    The DC-2XL is the one that was designed to interface with the chinese DC controller. Yes it has connections to control the spindle with a manual Pot.
    I am also a mechanical guy, but usinga break out board with Gecko's make wiring things up a no brainer.
    Some people buy double ended steppers and then put hand wheels on the back of the motor so they can still do manual machining. I didn't and am glad of that. My Mill is not yet converted, and I find turning the wheels such a pain after just telling the lathe where I want it to go.
    One of the really huge advantages of a CNC is that you can put the thing in an enclosure and keep all the crap from flying everywhere.
    Because I didn't have a mill when I first did my conversion, I went with timing belts in a 2:1 reduction. This made motor alignment much easier (and since I only had a 2A driver back then, my motors are not that powerful). Direct drive probably matches these more powerful Keling motors better to the load (Your rapid would be faster).
    If you have access to a mill make up some ball screw bearings and mount the motors like Steve did (http://www.5bears.com/cnc04.htm).
    That being said, I like how my X Axis motor is folded down out of the way.
    Attached Thumbnails Attached Thumbnails cnc newb wanting to convert HF 7x10-img_5699.jpg
    Regards,
    Mark
    www.wrathall.com
    Mar 2004
    Vienna, Austria
    I meant to ask, How are you planning to do the X Axis ball screw? I designed a ball screw installation around rolled ballscrews, and one installed on Z, but decided there wasn't enough space to install the screw I bought for X, and that a rolled screw without an anti backlash system is no significant improvement on the metric trapaziod (ACME style) screw I am currently using.
    Bellmouths here http://www.wrathall.com/Interests/interests_index.htm I turned up on the mini lathe.
    Regards,
    Mark
    www.wrathall.com
    Mar 2004
    Vienna, Austria
    How are you planning to do the X axis ball screw?
    Regards,
    Mark
    www.wrathall.com
    Oct 2009
    I'm going to ditch the stock location and mount the X axis ballscrew on the outside of the chuck side of the carriage. I know I won't be able to bring the carriage all the way past the chuck, so that dead space between the carriage and gear housing when the carriage is as far left as it can go is where I'll mount the setup. I am going to take off that piece where the stock X-axis screw is attached to the crank (dont know what its called) and make my own piece with alot more relief so I can slide the cross slide farther towards me and have a larger diameter capacity.
    I'm also going to can the compound slide and just make a spacer block to mount in its place for simplicity... and because my compound slide moves around alot. I'm going to do the Z-axis just like blades did in his project but my X-axis will be totally different.
    I was kind of leaning toward a direct drive on the X-axis, but I didn't know well it would actually work.
    So, you can use the cnc software to "jog" each axis by a certain incriment with a key stroke? Like, press (whatever) key to jog X axis in/out at (whatever) incriment? If that's the case, then I guess I won't need to add hand controls or a manual spindle control.
    Mar 2004
    Vienna, Austria
    When I replaced my cross slide with a T-slot table, I also increased the X travel. Can be really handy.
    With a CNC you don't miss the compound slide at all. A block of steel is far more rigid
    I put my Z axis motor at the other end, as then you can have all of the wiring going to the head end of the lathe (First photo below). After I burnt out the cheap chinese DC motor, I re-engined my lathe with a 1hp three phase motor running off a single phase to three phase invertor. I wired this up to the original direction/off switch and speed pot (The Homann speed controller weren't made back then). I have been meaning to get a speed controller and integrate this into the controller. The Chinese DC motor controller is in a box somewhere, the controller cover on the front of the lathe is currently empty.
    Direct driving the X will work fine, it is just not quite so compact that way. Since I only have a corner of my inner city balcony as a machine shop, compact was important for me. Those modern Keling motors with 3A Gecko G251s will easily direct drive both axis.
    The CNC software offers multiple chooses to jog. You can use the MDI (single line of code) interface and tell the machine where you want it to go to:
    G0 X25; Machine will head of at max speed to a diameter of X 25mm.
    You can use the jogging interface to move using keystrocks either for as long as you hold the jog key down, or a fixed distance per stoke (where the fixed distance can be easily changed with a single button push between say 1", 0.1", 0.01", 0.001", 0.0001"
    (This is implemented in TurboCNC, so I am sure Mach 3 and EMC will have at least this and even more sophisticated options).
    You can also implement an MPG jogging wheel (see here http://kelinginc.net/BreakoutBoards.html) so you can precisely manually control the movement of an axis with a wheel rather than a jog button.
    Putting handwheels on a powered axis has the following disavantages:
    Danger, spinning thing to hit your hands, pick up swarf etc.
    Knotchy movement when using steppers.
    Every time you touch it, the machine controller loses it's position, as steppers are open loop systems.
    I personally feel no disadvantage of making the machine CNC control only. YMMV.
    Attached Thumbnails Attached Thumbnails cnc newb wanting to convert HF 7x10-img_5706small.jpg   cnc newb wanting to convert HF 7x10-img_5707small.jpg   cnc newb wanting to convert HF 7x10-img_5708small.jpg
    Regards,
    Mark
    www.wrathall.com
    Mar 2004
    Vienna, Austria
    There is a good point made in the Blade Thread. You can't use the stepper bearings to control the leadscrew thrust, as they have not thrust bearings.
    Use a pair of AC bearings on one end of the leadscrew to control thrust. The link to 5 bears bearing block how to is in post #4. I didn't use AC bearings in mine, just normal deep groove ball bearings. Just one of a less than optimum features in my first CNC build
    Regards,
    Mark
    www.wrathall.com
    Mar 2004
    Vienna, Austria
    Oh, and you can never have enough QCTP tool holders. I bought mine from Shars.
    Regards,
    Mark
    www.wrathall.com
    Registered Crevice Reamer's Avatar
    Mar 2008
    Hi defrag. welcome to the Zone!
    I recommend these electronics for best performance and easiest installation:
    $289 1) Gecko G540
    $098 2) KL23H2100-35-4B 281 oz motors
    $050 KL-300-48 48V/5A PSU or $60 KL-350-48 7.3A PSU
    $437
    You may find some of this info helpful:
    help with old parts
    CR.
    Mar 2004
    Vienna, Austria
    Why pay $289 for a G540 when you only run two axis? For 2x $69 for G251's and a $30 you have exactly the same functionality for half the price.
    Regards,
    Mark
    www.wrathall.com
  • Page 1 of 2 12 LastLast
    1. Wanting to convert small mill to cnc
      By ramax in forum Australia, New Zealand Club house
      Last Post: 03-29-2009, 06:20 AM
    2. wanting to get into cnc routers
      By wildchild25 in forum DIY CNC Router Table Machines
      Last Post: 03-07-2009, 07:00 PM
    3. wanting to build a 2' x 4' or 4' x 4' to cut MDF
      By nikbrewer in forum DIY CNC Router Table Machines
      Last Post: 08-21-2008, 07:55 AM
    4. wanting to get into router/cnc
      By k2pilot in forum General Metalwork Discussion
      Last Post: 09-15-2005, 01:02 AM
    5. wanting a taig
      By SteveD in forum Taig Mills & Lathes
      Last Post: 10-21-2003, 10:26 AM
