Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 03-13-2005, 07:51 AM
studysession is on a distinguished road
Lathe help
I have a Sieg C6 Lathe. I have been suing it for aluminum and steel, but now I want to cut wood for a project. What do I need to do, to make it where I can cut wood with chisels on the Lathe?
I do not want to make any permanent modifications to the Lathe. Most of my projects involve aluminum and steel. But I do want to do a project or two with wood.
Thanks!!
Please check out my CNC blog
http://cncinside.com
Old 03-13-2005, 08:23 AM
MrBean's Avatar
Gold Member
MrBean is on a distinguished road
I'm not sure of the proper terminology, but can't you fit a toolrest to the cross-slide instead of the normal toolpost. Have a look at some pics of wood lathes. They have a kind of T bar that you rest your chisel on and guide it by hand.
Regards Terry.....
Old 03-13-2005, 08:44 AM
kong is on a distinguished road
Thats what i was thinking. Alternatively, just use your metal turning tools to cut the wood! Anything designed to cut ali should work on wood.
Not sure the effects of wood turning on your metal lathe though, surely all that dust is gonna do some damage, particularly if the wood is a bit wet?
Old 03-13-2005, 09:30 AM
Has anyone done this before?
Gold Member
JFettig is on a distinguished road
I know lms sells stuff to mount wood and has the steadyrest(I think thats the term for it) for the 7x12, you may want to look there, I bet you could make your own.
Jon
Old 03-13-2005, 10:01 AM
RotarySMP's Avatar
RotarySMP is on a distinguished road
I've turned wood on a metal lathe. Just do it. Nothing special you need to watch out for. If you want to use hand held wood working tools, get or make a t shaped rest. COvering your bed will make the clean up easier.
Are you happy with that model lathe? It has just recently been stocked by a local company, and looks like the nicest of the 9X models.
Regards,
Mark
www.wrathall.com
Old 03-13-2005, 10:07 AM
YES - I like it. Would like to do a CNC conversion eventuially. I have a CNC Mill. It is a Sieg Micro Mill. I like them both just wish I bought a bigger mill.
Using your CNC Mill as a CNC Lathe lstool Knee Vertical Mills 10 08-02-2010 01:06 AM
Help me buy my first Mini Lathe Highfly Mini Lathe 20 05-10-2005 03:07 AM
OneCNC XR Series Lathe CAD/CAM Released: OneCNC Product Announcements & Manufacturer News 0 03-07-2005 05:20 PM
Buying my first lathe, Jet, Grizzly, Central, Prazi Noah General Metal Working Machines 9 09-05-2004 11:35 AM
Mastercam lathe crash course CNCnUtZ Mastercam 6 09-26-2003 02:03 AM
