Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 03-12-2005, 09:14 AM
Trapper14 is on a distinguished road
turbo cnc no g70 g71?
I am shocked that Trubo CNC does not have g70 g71 roughing finish canned cycles! At least thats what I heard. If this is true, I think I may go to mach 2 or 3 over turbo CNC what do you guys think? I personally think that canned cycle saves ooooodddles of time if you don't have a CAM program, although I do I don't like using the lathe portion of matercam, its very weird IMO. So let me know guys!
oh btw im deep in the middle of a conversion with member Rotary, Great guy knows tons fo stuff! You might know him from his Site Wrathall
Its going to be ballscrews with
Automation Direct $39!!! 276oz steppers
controlled by 2 xylotex boards.
Powered by a Automation Direct 32VDC 4A Powersupply
I just ordered a Parallel Port Card from CNC4PC.com
I ahve attached some pics ofa few of the parts that have been made so far
The x axis stepper NEMA 23 mount, a pic of powersupply and drive cover. Hope you enjoy oh btw im still in need of limit switches/homing switches any suggestions? I don't know anything about those things.
I made the parts on a Komo VMC x travel 144"(12ft)x y axis 20" at work
I make some big stuff
One more quicky question. Has anyone changed out the motor in there Siege Lathe I have a Homier and wouldn't mind adding a little more boost, say a 1.5hp tread mill motor? Would it work, or would the thing need a new controller and all that? Thanks
Sean
ID:	6150   Click image for larger version
ID:	6151   Click image for larger version
Name:	motor mount.jpeg‎
Turbo CNC and geckos snoman70 TurboCNC 9 03-30-2005 07:47 AM
Turbo CNC liquidrush TurboCNC 1 02-07-2005 09:36 PM
Turbo CNC Not Running.... Setup? Davedbq TurboCNC 4 02-04-2005 02:20 PM
Questions about Turbo CNC Hack TurboCNC 1 12-06-2004 09:49 PM
help setting up turbo cnc landart TurboCNC 1 01-09-2004 09:59 AM
