Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 09-15-2009, 08:17 AM
EvilSmirk is on a distinguished road
Pulse Motor for Auto Feed?
I'm looking at switching from using the gear set to a pulse motor for turning the lead screw for a really fine finishing cut.
I've turned and attached an extension to the lead screw past the pillow block and have mounted a piece of 1/4" plexi to the end of my bed because I was using the Ultra-Fine Power Feed mod that Varmint Al posted on his website some time ago. But I've been having issues with the cheaply built animation gearmotors from MicroMark, their shipping costs don't help either.
Any way, I have a similar size pulse motor laying around and wanted to look into using that instead of the animation gearmotor. Can I wire up a pulse motor to a variable power supply and use the voltage/current to adjust the speed of the motor?
If so, can anybody tell me which of the million or so wires coming out of the pulse motor I need to work with to make this work?
I know testing will need to be done to determine torque, speed, etc. Just was thinking about it last night a little bit and wanted to see what the experts thought.
Old 09-15-2009, 10:48 AM
TroyO is on a distinguished road
I don't know the details of stepper motors, I haven't done anything with them. (Yet)
But, you might find this interesting....
http://www.autoartisans.com/ELS/
http://tech.groups.yahoo.com/group/E-LeadScrew/messages
The E-Leadscrew project is (As I understand it) a build-it-yourself (like the Shumatech DRO) circuit board that you use to control a stepper motor for your leadscrew. It lets you automate threading and other tasks... you set the TPI and length and it controlls the leadscrew based on spindle RPM. It also can do smoothing cuts, etc. No changing gears, as it's all controlled by the ELS.
Very cool idea...
Guidance in purchasing a metal lathe w/ auto feed ZPenn Want To Buy...Need help! 1 05-20-2009 06:00 PM
datasheet for nippon pulse motor PJ55P1U36B ? aladin01 Stepper Motors and Drives 0 02-17-2009 05:22 PM
auto feed 4th axis? Teyber Benchtop Machines 25 06-30-2008 10:37 AM
Nippon Pulse Motor PJ55 (PJ55B1-28B), Info/Usable? madcow Stepper Motors and Drives 1 07-31-2006 03:58 PM
bestline auto feed problem on a series 2 brownandsharp Bridgeport and Hardinge Mills 2 07-27-2006 05:01 PM
