| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
I'm converting this machine to CNC and will use a VFD and new 3 phase motor for variable speed. There a several ways to skin that cat, resulting in a wide range of possible spindle speed ranges. I'm thinking that it would be nice to have the option of getting to around 3000 rpm, only for occasional use on small diameter parts. Can the bearings take this, with the understanding that most use will be well inside of the 2000 rpm that the stock machine maxes out at? |
| Speaking of spindles, does anyone know how to lube the main spindle bushings of the HF 8x12? There are no lube points. Are they self lubricating? Do you just squirt some 3&1 at them? EDIT:From looking at the head stock exploded view, the main spindle appears to have ball bearings with oil rings (front, and back) covering them up, along with a tube spacer for the rear bearing. This still doesn't answer my question though. Should I simply force a little 3&1 through the oil rings? Anyone?
__________________ My Lathe: HF 8 x 12/14 Last edited by Freddy Warbird; 09-22-2009 at 06:35 PM. |
| HF 8X12 Vari-speed | Ed Boysun | Mini Lathe | 13 | 03-06-2007 04:03 PM |
| maximum lathe spindle bearing speed? | ScottC | Mechanical Calculations/Engineering Design | 9 | 01-28-2007 06:15 PM |
| Maximum speed | fbazan | Yeager Automation | 0 | 09-13-2006 09:30 PM |
| New Taig, 8 ipm maximum rapid speed? | fivaxis | Taig Mills & Lathes | 5 | 05-11-2006 08:55 AM |
| What is the maximum practical speed you could run a stepper at? | phantomcow2 | Stepper Motors and Drives | 6 | 03-15-2006 08:15 PM |
