Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 09-11-2009, 04:45 PM
Nelson_2008 is on a distinguished road
Why do I keep stripping the inside of the lead screw drive gear?
Hello,
I was turning down a 2" piece of UHMW polyethylene with my Microlux 7x14 lathe, at 1000 rpm, using automatic carriage feed, and taking light cuts, when all of a sudden the lead screw stopped turning.
I took the cover off, changed out the damaged 80 tooth drive gear, and then it worked for a few more minutes before the same thing happened again; in each case, the keyway simply gouged out the inside of the plastic gear.
Has anyone else ever had this problem? I wonder what could be going on here?
Regards,
Nelson
Old 09-12-2009, 12:25 AM
Ok, when I put another new drive gear on the lead screw, I cannot turn it at all by hand (I already removed the small gear that drives it). So it looks like the lead screw is basically "frozen".
Has anyone else had that happen before? What could cause this to occur?
Old 09-15-2009, 08:06 AM
EvilSmirk is on a distinguished road
Sounds like you might have a binding issue with your lead screw at either the pillow block or the halfnuts. It should turn by hand without too much effort.
How to mount lead screw inside a bearing? CuttersCov DIY-CNC Router Table Machines 24 08-13-2011 07:25 AM
How do you mount a lead screw/lead nut? jbluetooth DIY-CNC Router Table Machines 2 12-01-2008 04:10 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Ball Screw or Lead Screw? Which is Better? ljoe1969 DIY-CNC Router Table Machines 4 07-28-2004 08:49 AM
