Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 08-27-2009, 07:23 PM
sunnyday is on a distinguished road
Easiest way to convert HF 8x12 lathe to variable speed control
Is there a full kit that can be purchased to convert the HF 8x12 to a variable speed control with DRO option ?
Old 08-28-2009, 05:43 PM
blades is on a distinguished road
Doubt there's a kit, but TroyO did it himself using a relatively beefy 1.5hp motor out of an old treadmill. Sounds like a very worthwhile mod!
Old 09-01-2009, 10:24 AM
TroyO is on a distinguished road
There's no kit that I know of. Mechanically it's not that hard.. tap a few holes for the motor mounts (Or modify the motor base to fit the existing holes) and add a pulley. That will depend on the motor you get... there are better options than the treadmill motor (Such as one that's TEFC.. Totally Enclosed Fan Cooled) but if you already happen to have a treadmill that you want to get rid of... the price can't be beat, LOL.
The wiring is time consuming, but not really that hard. I might have changed a few things if I were to do it again (The biggest one being.. since you no longer need the step pulley/toothed pulley at the back of the lathe you can just take it out. That leaves a big old area under the belt cover I would have used to put the DC motor controller had I realized how much space there was. Hindsight 20/20)
CNC4PC Variable Speed Control Board Bubba TurboCNC 10 08-07-2009 10:01 AM
where to buy a variable speed control cob General Metal Working Machines 5 10-01-2008 01:37 PM
convert rf45 type to belt variable speed and some cnc info? ataxy Knee Vertical Mills 20 09-03-2006 10:58 AM
Variable speed control for routers bgolash DIY-CNC Router Table Machines 1 12-21-2005 02:23 PM
can i use this for variable speed spindle control? cowanrg General Electronics Discussion 7 06-24-2005 12:44 AM
