Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 07-26-2009, 06:53 PM
HankMcSpank is on a distinguished road
Sieg C2 motor control board schematic?
Hello,
Does anyone have a schematic for the DC motor speed control board that is shipped with the Sieg C2A300 mini lathe ...I'd rather repair the broken board I have vs buying a new board!
tks,
Hank.
Old 09-08-2009, 11:35 PM
AndrewE is on a distinguished road
C2 repair info
The following site will repair the board for half the cost of a new board.
http://www.repaircontrol.com/
http://www.repaircontrol.com/SCRControl.htm shows a basic diagram, but I have not yet found a circuit diagram.
http://www.mini-lathe.com/Mini_lathe...ot/trshoot.htm says the Mosfets are the likely culprit. Simply replacing both of them may fix the problem.
If you ever do find the circuit diagrams, let me know.
Old 09-09-2009, 03:13 AM
Many thanks...just to give some closure here - that board was completely toast ...the Ebay seller was very shrewd - he didn't say it was completely nuked & only photographed it from the top - which looked fine. However when I saw the bottom, it had obviously been subjected to a major amount of voltage/current - all the silicon was short - many of them melted - some PCB tracks gone & the board swollen around many tracks. I picked up a Danfoss DC motor control board for £20 - which isn't meant for the Sieg but was cheap enough to spend an hour or so adapting!
Need help to locate stepper motor control board plus driver Techbuilder Stepper Motors and Drives 1 10-16-2008 08:53 PM
Need help to locate stepper motor control board plus driver Techbuilder DeskCNC Controller Board 9 10-14-2008 07:11 AM
Need schematic for motor on/off control EL34 General Electronics Discussion 10 09-25-2008 07:59 PM
Boss 4 RCK board Schematic jodybo Bridgeport and Hardinge Mills 1 03-26-2008 05:42 PM
breakout board schematic giorgiocnc General Electronics Discussion 7 11-13-2005 10:02 AM
