| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
I need to make a more precision 5/16" mandrel for a diamond drum to put in a mill. The rubber-tire types used for sanding drums SUCK really badly for runout, and it's not just the rubber- the steel mandrel inside it may have 30 thou of runout or more. I used a 5/16" bolt on the Sherline, it had much lower runout at firsy, but in the final cutoff stage the parting tool bound up near the end and it bent it. I found that on the whole it just bends too easily. I could get a higher grade bolt... or maybe a screwdriver shaft?? Just looking for stiffer steel here. Also I may need to make a similar custom mandrel for a Dremel bit. Well the screwdriver shaft, I'm probably not gonna find a 5/16" shaft for the first type of mandrel I just described, but I could probably use it for this Dremel one. |
| What about a 5/16 expanding internal collet? http://www.jfkprecisionproducts.com/internalcollets.htm
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| Do you have a tool supply place nearby? They would have steel dowel pins or drill blanks you could use. Or if that's too hard of a material, I think you can get steel round stock from Lowes or Home Depot, which would run more true than a bolt. |
| In need of Mandrel Bending | Twil759 | Employment Opportunity | 1 | 01-14-2008 04:26 PM |
| cnc controlled mandrel bender controlled by mach3 | timmyb199 | Bending, Forging,Extrusion... | 5 | 05-30-2007 07:35 PM |
| Mandrel Bent 4x2 316 wall... | VinceSRC | Bending, Forging,Extrusion... | 3 | 02-02-2007 08:22 AM |
| How would you control a CNC mandrel bender? | panozeng | General CNC (Mill and Lathe) Control Software (NC) | 4 | 07-18-2006 10:34 PM |
| mandrel bending | MBG | Bending, Forging,Extrusion... | 4 | 03-22-2005 02:29 PM |
