Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 06-30-2009, 01:07 AM
yang_cnc is on a distinguished road
Question about tooling on HF 7x12?
If I ask a stupid question, please kindly ignore it
I read the manual of the HF 7x12, and read the tutorail on littlemachineshop.com, they do not EXPLICITLY mention which tool bit size the lathe uses.
But LMS does have product like item 1261 pack, which says 5/16" tool is compatible with HF 7x12, I just want to confirm it here before I order it.
Also, for parting tool, I do not really see much choice, I only found LMS item 1551 parting tool holder. Otherwise, I found nothing else on other websites. Do you have any info about paring tool and its holder?
thank you so much!
Old 06-30-2009, 09:56 PM
ibuildstuff4u is on a distinguished road
Good question!
I'm 99.9% positive that it will take up to a 5/8" tool. As for the parting tool holder, that's about it unless you buy a parting tool with replaceable inserts. They are nice, but expensive!
Have fun with the new lathe!
Dale P.
Old 07-01-2009, 01:58 AM
Thank you for the confirmation!
One more question, what cutting fluid should I buy? totally have no idea
Old 07-05-2009, 07:01 PM
Just abut anything will work. I usually buy the stuff from LMS and have been very happy with it. It cools the work and I have NOT had any problems with rust on the machines. You can use oil too, but it makes a mess and can smoke a bit when you run things hot.
Dale P.
Newbie- First Tooling Question Phishaholic Tormach PCNC 28 02-09-2009 04:10 PM
tooling question CASTLEVILLE General Metalwork Discussion 8 02-03-2009 11:35 AM
Tooling Question jmneissa Jet Engines and Ram Jets 0 05-19-2008 07:55 PM
R8 tooling question jsansoterra General Metal Working Machines 3 04-10-2008 07:43 PM
TL1 Tooling Acc. Question elaganis Haas Mills 9 06-15-2007 10:24 AM
