| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
Sherline Lathe: Chucked up an 1-1/2" x 5" alu round in a 3 jaw chuck. Need to part off 1/2", live centre in previously drilled centre hole - because I know it's going to need some tail support. Parting off is a horrible job and yes it jammed 3 times locking up the motor and pulling my stock half out of the chuck. It's OK until you get about 1/2" into the stock. My guess is that the cut off tool must be flexing as it gets further into the stock. I get good chips until it binds. I have low speed and cutting fluid. Not sure what I am doing wrong, maybe the Sherline is not built for this size stock. Got the 1/2" disc off in the end. Rechuck the smaller disc put a centre drill in the large chuck on the tail stock. The centre drill wobbles as it comes into contact with the end of the stock - is this normal? Should I be knocking the taper harder into the tail stock before I start drilling? After the centre hole I chuck up a 5mm drill bit in the chuck on the tail stock and succesfully drill a hole through my 1/2" disc. Now because I want a larger hole I go up to an 8mm drill bit, well this is a drama, the bit keeps jamming and ends up spinning the chuck in the tail stock. 4 or 5 attempts at get past the smaller taper made by the smaller drill until I am drilling again. Up to a 12mm drill, and yes the same problem. Are the flutes on my drills too sharp? I have noticed that in a hand drill in thin metal stock the drill just wants to turn into a screw and near pulls the drill out of my hand. The 3 jaw chuck certainly mars up the surface of the stock - is this normal for aluminium? I tend to tighten the chuck enough to make it difficult to unchuck, bring in a fear of skinned knuckles when using the tommy bars to release the stock. If I don't tighten the stock up so tight it just moves on me. I find that getting a clean finish is difficult since the handwheels don't seem to be so freely moving, they seem to bind ever so slightly part way through a full rotation - both cross slide and feed seem to be not so smooth. Anyway, after reading this maybe you guys have some comments. Feel free to point out my short comings |
| The Sherline can handle this. It is not right for the center drill to wobble. Are you sure you started it at the basic center of rotation? I have had trouble where the tailstock isn't pointing dead center into the axis of rotation. You can kinda adjust the brass shim on the tailstock-to-rail mount.
A SteadyRest will stabilize the 5" stock for end cutting.
The coiling "swarf" is desirable. If you are getting chips, you may be turning too fast on the motor or not feeding it fast enough to keep the coil continuous. If it's not coil-swarfing, vibration may occur. I'm not sure why you're enlarging a previous hole by choice. The bit is more stable on one big drilling operation. |
I have never checked the tailstock to headstock centre, the Sherline is still quite new and I would have assumed it to be correct. Will check by chucking up a dead centre and have the live centre in the tail stock. Yes, use the Steady Rest - that makes more sense than using a live centre on the tail stock. I do understand that it's not safe to run the parting tool too far when using a tail centre. "Center drill sucks" - shouldn't be, the chuck and center drill are both from Sherline. I assume that the center drill is OK to mount into the Jacobs chuck ?? Re: drilling a large hole. You mention to just use the final drill size rather than starting with a smaller drill. mmmm, OK - so need to ramp up the sizes. Sorry to say that I don't have a bandsaw, so I am using the lathe to dimension stock. |
| Sherline Cnc 4400 Lathe | STIELJTES | Mini Lathe | 2 | 08-09-2009 07:59 AM |
| Newbie- Homebrew spindle challenges/not a machinist | Billhill | General Metal Working Machines | 6 | 03-06-2009 08:29 AM |
| 7x CNC Lathe or sherline? | Jason23 | General Metal Working Machines | 0 | 09-10-2008 01:08 AM |
| Today's favorite line drawing to g-code program | IQChallenged | G-Code Programing | 3 | 12-27-2007 01:57 PM |
