Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: New Sherline lathe! I'm ecstatic!
    Nov 2008
    Well, after waiting for a deal to show up...
    Local shop guy puts up a Sherline 4400 on Craigslist for $500. That's the LONG one. He'd moved on to bigger metalworking lathes and needed the shop space cleared.
    And it just kept getting better. He had the CNC leadscrew and NEMA23 mounts. Threw in a stepper then dug in a bin and pulled out another new stepper! And there's tons of other miscellaneous parts I have no clue on. I recognized a steadyrest. I've never used a lathe. And it's all mounted on a neat case-box.
    Didn't have chucks but I have a Sherline Rotary Table on my Taig and already have the 3-jaw self-centering and 4-jaw independent here. No problem!
    Oh yes yes I have the lathe, it's here in my hands!
    Now one of my first things, I need an 8" long 0.8" OD (plus a 1" flange, so I need to machine the outside) UHMW tube with a 5/8" ID. So I'm gonna bore out 1" UHMW rod stock. Now do I start by drilling a pilot hole and bore it out to diameter, or should I just use a large drill bit in one shot? I think I even have a good long auger of this size, but would that be a bad idea due to the self-feeding nature of the auger trying to suck its way into the plastic?
    Will the drill bit ensure the hole is centered, so it maintains a fixed wall thickness when the outside is machined down? See, I know a second bore operation should definitely be centered.
    Registered Teyber12's Avatar
    Jul 2008
    i am a lathe noob and never seen a sherline-
    but because nobody else responded... In plastic just drill a hole big enough to fit the boring bar in there, then just use a boring bar till your at the right size
    congrats on the purchase!
    Nov 2007
    Pics man, PICS! Congrats on the purchase!
    Nov 2008
    I don't have a boring head though. Plus a boring bar can't go really deep, right? I need a hole like 6" deep on at least one of the 2 things I need to do right now. Which, I can see where I could bore out a guide hole for the drill bit, and boring is more accurate than ram-drilling it, but the drilling is probably more than accurate enough.
    Actually how does tailstock drilling even work?? The tailstock is fixed, and the leadscrew does not move it. Do I just move the tailstock to the other side of the crossslide and let the crossslide push it?? The crossslide won't be able to withdraw it from the drill bore.
    Actually I'm kind of annoyed to realize that a) the nice, expensive 4-jaw indy and 3-jaw SC chucks I have for the Sherline rotary table will not work on the Sherline lathe. At least not without riser blocks. Once the jaws are opened at all, the outer bits will strike the bed.
    Plus the tailstock... what's with this MT0 crap? I found I need a bullnose live center and MT0 jacobs chuck, probably a boring head, and realized that MT0 stuff is kinda rare and I can't get anything locally, and I'm gonna have to pay through the nose. Basically double or triple what normal MT2 or so stuff costs. I mean HFT I could get a MT2 bullnose for $25, jacob's chuck is $7. Sherline's MT0 bullnose is like $75.
    Really I need some of that either way to use with the Sherline tailstock for the Taig mill fitted with the rotary table, even without the lathe tool, but the MT0 size is a huge liability.
    Well, I got it all set up for CNC now. I mean it was a good deal with the CNC kit and all, and it's got an impressive 17" between centers which may be necessary at some point.
    Registered acondit's Avatar
    Apr 2005
    Look up some of the Taig stuff. It used to (many years ago) be much better priced than the Sherline stuff. You can't use everything Taig on the Sherline but probably the centers.
    Alan
    Nov 2007
    Quote Originally Posted by MechanoMan View Post
    Your tailstock should have essentially a spindle or quill built into it that you crank out, much like a drillpress, except the chuck will be stationary (not spinning). Is this assembly missing on your tailstock?
    Does your tailstock look like this one?
    Feb 2006
    us
    Hey Mech, I would definitely drill what your trying to do. Now hopefully your drill chuck will hold a big enough drill bit to do what you want. To drill simple retract the drill chuck as far back into the tailstock, then move your tailstock up to your piece, lock your tailstock down and start drilling, when you extended the chuck as far as it goes retract the chuck and slide your tailstock in a little more and repeat process. Don't forget coolant of some type(wd 40 works).
    But honestly it sounds like ya need a bigger lathe for what you want to do or for the size drill bit you need you,ll probably need to grind the end of it so it can fit in your chuck.
    Good Luck!!
    Nov 2008
    I do have that tailstock. However, the depth of the motion with just the tailstock crank is very shallow, and I don't see how it'll do the job.
    I've got the 17" between-centers lathe. I was looking to bore out say a 1" dia, 6" long piece of Delrin with a 1/2" hole 6" deep. So the plan was to first dig a center with a center drill mounted in the non-turning tailstock chuck, then chuck a >6" long drill bit on the tailstock chuck, use the CNC leadscrew to drive it in 1/2", pull it out to clear the debris, and peck again in cycles.
    But there's no way to drive the tailstock chuck in like I'd thought. So I seem to be looking at just drilling/boring like a 1/2" starter hole with the lathe, then trying to use it as a guide hole to finish the drilling with... I guess a hand drill, in which case I've no idea how to hold the rod and keep it from spinning either.
    Or unlock the tailstock gib and manually push it down the bed slide?
    Isn't there a way to mount a drillbit on the crossslide table so the leadscrew can drive it in? All I could think of was unlocking the tailstock gib and somehow tying the tailstock to the crossslide so the leadscrew will take it in and out.
    Aug 2007
    I would look at McMaster for UHMW or Delrin tubing with the correct ID and then turn the OD to whatever you need. A 6" or 8" long piece in those chucks won't be held securely at all- the length of the jaws is just too short, and the bore through the chuck is too small (.68") to clamp the piece in the middle.
    I bought a Sherline 4400 about 3 years ago. I bought a Grizzly G0602 3 months ago. I love the G0602. The Sherline? Well, it's destined for ebay.
    Nov 2007
    That's a question only you can answer.
    You can do anything you can imagine, but how well it can be done is the real trick. All depends on your creative genius and what you have on hand that you can make do with. What you describe is definately doable though, but with somewhat light drilling pressure since it wouldn't be as stout of a setup as the tailstock would be.
    Aug 2007
    Boring the hole
    Use a one undersized drill bit and then come back thru with a reamer of the proper size. Use Air or coolant as you ream and go slow. you don't want to melt the delrin back into itself.
    Jan 2007
    You drill to the depth of your quill in your tailstock, then you stop the lathe, retract the quill, unlock the tailstock, move it forward into the hole, lock the tailstock down, then turn on the lathe and drill to the depth of the quill in the tailstock again.
    Repeat till you are at the necessary depth. If you try and move the tailstock with the crossslide, you will have a very inaccurate and wobbly hole.
    Wade
  • Page 1 of 2 12 LastLast
    1. New Sherline! I'm ecstatic!
      By MechanoMan in forum Taig Mills & Lathes
      Last Post: 06-03-2009, 04:38 PM
    2. 7x CNC Lathe or sherline?
      By Jason23 in forum General Metal Working Machines
      Last Post: 09-10-2008, 01:08 AM
    3. What Sherline Lathe Accessories To Buy And When?
      By Too_Many_Tools in forum Mini Lathe
      Last Post: 10-11-2007, 12:46 AM
    4. Sherline lathe question
      By bnalls in forum Mini Lathe
      Last Post: 08-14-2007, 09:44 PM
    5. Sherline 4000 Lathe
      By sleepy23 in forum Mini Lathe
      Last Post: 11-09-2005, 04:44 PM
