| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
| Hello All, Here is a thread of an Optimum 1080x300 conversion that I am almost finished with. I have been at it for one and a half years now and really want it done! I chose to do a gang tool as I haven't seen many of them on here and I will be able to fit four or five tools to the cross slide. Disadvantage is that you cannot use the tailstock but should I ever have to I will fit a quick change toolpost. I had taken photos of all of the steps but sadly my camera went 'missing'. I will add photos of the assembly as it happens, the only part that needs work now is the mounting of the encoder and single pulse sensor for threading which I hope to do this weekend. The control will be Mach and DeskCNC, I have built a box for both and then I can run them against each other. Enjoy! Greg www.cncdirect.co.za |
| Hi All, There's been little progress, here's the lathe with the covers on. Both axes are running nicely at 7400mm/min, I'll slow that down later but it's cool to watch for now! I still need to add the encoder for threading and the single pulse/rev sensor. Then make some tooling for it, never ends! Enjoy! Greg www.cncdirect.co.za |
| Hi All, Thanks Teyber12 and blades, this project is on hold at the moment while I finish this one: http://www.cnczone.com/forums/cnc_wire_foam_cutter_machines/82856-my_new_hot_wire_build-post626091.html Regards, Greg www.cncdirect.co.za |
| Optimum BF20L CNC conversion | JanHenning | Vertical Mill, Lathe Project Log | 19 | 03-11-2009 12:09 PM |
| gang tool holder | brucesu1 | Shopmaster/Shoptask | 8 | 04-22-2008 09:34 AM |
| C6 - Gang tool holder? | PEU | Syil Products | 0 | 04-14-2008 12:28 PM |
| advice for optimum d 180x300 lathe | solinvictus | Mini Lathe | 2 | 02-15-2007 03:11 PM |
| Gang tool cnc mini? | Call Maker | Mini Lathe | 6 | 03-26-2006 12:38 PM |
