Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 05-04-2009, 11:04 PM
CS900's Avatar
CS900 is on a distinguished road
Quick change gearbox for HF 8x14
Well everyone, I just got done with my junior machine design project for school and thought you all would probably enjoy this.
It's a quick change gearbox capable of tuning: .050in/rev, .010 in/rev; 12, 16,18,20, 24, 28, 32, 40, and 48 tpi. sorry, no metric here. It also has a built in quick change tool feed direction function.
I've done a complete design including fab drawings, stress calculations, fatigue life analysis, press fits, you name it. this could actually be built if someone were so inclined.
Old 05-04-2009, 11:15 PM
CS900's Avatar
I guess you probably want to see what's under the cover as well...
Old 05-05-2009, 08:59 AM
caleb105 is on a distinguished road
I am very interested in this (ME student myself).
Did you design using existing gears, or did you just pic random teeth and diameters, which would need to be custom made?
-Caleb105-
Harbor Freight X3, Keling 387inoz 23's, 640inoz 34, G203V's, Homebuilt 65V PSU, PMDX-122 BOB, NOOK XPR screws, NOOK SBN ballnuts, Shuttle Pro2, Mach3
Old 05-05-2009, 12:11 PM
CS900's Avatar
-Caleb105-
they are all pre-existing gears, and can be bought from QTCgears.com. they even had the CAD models for them already, saved me a bunch of time. They do however, require the bore to be enlarged, as it needs a fairly beefy shaft to hold them all without much deflection while the gears are engaged and running.
Old 05-05-2009, 02:14 PM
I would be interested in any information you have!
Thanks!
-Caleb105-
Old 05-05-2009, 06:29 PM
CS900's Avatar
I can give you the drawings if you'd like.
Old 05-06-2009, 09:24 AM
I just sent you an IM with my info.
-Caleb105-
Old 05-07-2009, 02:04 PM
TroyO is on a distinguished road
Wow!
That's pretty impressive. I have an 8x14, and would love to have a quick change gearbox for it, but realistically I would never take the time to build it. :-(
I'd love to have the drawings though, if you wouldn't mind..... so I can drooll and convince myself that someday I'll actually make it.....
I'll shoot you a PM.
Old 05-07-2009, 02:16 PM
CS900's Avatar
I'll see about posting up a .zip file with the drawings in it for everyone.
Althouth i've already noticed one design flaw already. a stupid mistake of course...
the gear "arm" on the very left hand side in the second picture; the shaft that goes through the large gear and linkes it to the other gear on that shaft, for whatever reason, I made the shaft a press fit into the outside housing pieces, when in reality, the gears should be pressesed onto the shaft, and the shaft rotate freely around the housings. An easy fix, but still stupid.
Old 05-07-2009, 06:12 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
suddenly the 9x20 seems very attractive for those wanting a quick change toolbox
just playing, great work on the model!
  #11   Ban this user!
Old 09-22-2010, 05:50 PM
boxcarmj is on a distinguished road
Has anyone built this as yet, or have more info on it? Thank-you Mike J.
  #12   Ban this user!
Old 12-23-2010, 12:43 AM
metalmill52 is on a distinguished road
I have an 8 x 14 Lathemaster and would be very interested in building this gearbox! Does anyone have the drawings? Please let me know. Thanks so much!
Bill C.
Mini Lathe quick change gearbox trixter Mini Lathe 3 02-19-2009 05:23 PM
quick change gearbox krymis Mini Lathe 7 02-09-2009 03:39 PM
quick change R-8? replicapro Benchtop Machines 10 04-14-2006 11:00 AM
Quick change router bit wjbzone DIY-CNC Router Table Machines 13 06-07-2005 01:56 PM
Quick change bit holder Laff Riot Machine Problems, Solutions , Wireless DNC, serial port 5 04-17-2003 12:48 AM
