Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 01-21-2005, 08:41 PM
pminmo's Avatar
pminmo is on a distinguished road
How do I improve the accuracy of the tailstock spindle on my HF 7 x 10
If I put a 1/4" bit in my tailstock chuck and advance the spindle a
few inches, I get significant play, probably around .05in. Is there
an adjustment or modification that I can improve this?
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 01-22-2005, 12:05 AM
HuFlungDung's Avatar
Moderator
I'd be careful and take a look at how far out the spindle moves out before it comes right off the thread. You don't really want it hanging out that far, and by the sound of your description, you may be doing just that.
Use a stubby spotting drill or a center drill to start the hole in the end of the workpiece. Don't expect to start a flimsy drillbit in the end of a piece without an accurately placed start mark.
The end of the part also needs to be faced square before you attempt to drill into the end of it, or it will force the drill to wander off. You might be surprised that even on a large lathe, relatively small details like this will flex a 3" diameter spindle.
Another thing to look at is the accuracy with which you are chucking the part. If the start dimple is off center because your chuck is no good, then the drill will wobble as it attempts to follow that dimple, and flexure of the tailstock will ensue.
Old 01-22-2005, 02:38 AM
Konrad's Avatar
Konrad is on a distinguished road
It could be worn out??
If that's the case, the spindle can be chrome plated and ground oversize to suit the honed I.D
Konrad
Old 01-22-2005, 09:34 AM
Gold Member
JFettig is on a distinguished road
The tailstock on the mini lathes kinda suck in a way. make sure you do as huflungdung said and check the clamping of the tailstock. It is very easy to clamp it down and have it be off center.
Clean off the ways and the bottom fo the tailstock to make sure.
-edit-
wow its early I now see what your saying, yeah, its really not all that high quality stuff make sure to start your hole with the quill, or spindle or whatever as far in as possible, that way it has something to guide it. yes I agree, its kinda wack. That is one of the things I want to do with mine, make a new tailstock.
Jon
Ballscrew Basics Swede Linear and Rotary Motion 94 09-06-2011 07:23 PM
Sherline spindle to 30k RPM -- am I crazy? nicad General Metal Working Machines 21 11-17-2010 03:57 PM
CNC Controlled Spindle motor speed control gregmary General Electronics Discussion 13 02-27-2009 08:01 PM
Gilman box spindle pics Swede Benchtop Machines 5 03-30-2005 10:41 AM
2.2KW Allen Brad. Spindle motor? GalaticDan Servo Motors and Drives 2 02-02-2005 12:46 PM
