Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 04-29-2009, 04:39 PM
Cartierusm is on a distinguished road
9x20 CNC Threading Questions
I've just realized something and hopefully someone can give me an answer.
In a normal manual lathe threading operation the spindle is tied in with the lead screw either by belt or gear. So positioning is not lost by way of the threading dial. On a cnc threading operation the z and spindle are not sync by a physical mean but by a pulse index. So if you stop the lathe to check to make sure a bolt fits on the new threads you just cut won't the positioning be lost? Or is the pulse index used for more than spindle speed timing but for positioning as well?
Old 04-29-2009, 04:48 PM
Runner4404spd is on a distinguished road
position is lost. as far as i know in order to keep the spindle synced you would need an encoder and i don't think mach 3 does that.
Old 04-29-2009, 05:11 PM
I do have an encoder on the spindle. It's the C3 board from CNC4PC. It gives mach a single pulse index that way mach knows the actual spindle speed so it can sync the z axis. Mach must have this in order to do threading on a lathe or a 3 phase motor with a vfd.
Old 04-29-2009, 05:58 PM
jhowelb is an unknown quantity at this point
I have made a practice of stopping Mach 3 to test the fit of a nut and then cutting a bit deeper.
As long as you don't move the slide manually or quit Mach or remove the piece from the chuck then Mach still knows where the slide is relative to the piece and will calculate the angle of the spindle using the pulse.
Try it on a practice piece first!
Old 04-29-2009, 09:17 PM
Thanks I'll do that. I figure that even trying a nut might move it a hair.
Old 04-29-2009, 11:07 PM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Position is not lost with Mach3.
If you have one slot for the index sensor, it knows where that slot is. If you have multiple slots (or reflective markers, Hall effect magnets, or whatever), Mach3 wants one of them to be 50% wider than the others, again so it knows that position.
Cheers,
BW
Problem- threading gear interference, metalspinning questions gmac Mini Lathe 1 07-10-2008 09:57 AM
Threading questions stuby General Metalwork Discussion 11 04-06-2008 04:48 PM
HF 8x12 vs 9x20 edo Mini Lathe 9 03-06-2007 05:18 AM
Newbie Questions! HF 9x20 vs 8x12 medfoch Mini Lathe 10 01-12-2007 12:19 PM
Taig lathe Threading and CNC questions anoel Mini Lathe 5 01-12-2004 04:43 PM
