Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 04-29-2009, 03:33 AM
aaron p's Avatar
aaron p is on a distinguished road
Best lathe for under $600
Im wanting to buy a lathe to make simple spacers and polish round small parts on. Most stuff is 1" aluminum or smaller. 90% of the time it will be 6061 aluminum bar. Any recomendations? Do these small mini lathes have power feeds on both X and Z to do facing and turning operations?
"We can't solve problems by using the same kind of thinking we used when we created them", Albert Einstein Thinking outside the box 24/7........
Old 04-29-2009, 10:07 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
This is about the lowest cost dual power feeding lathe:
https://www.travers.com/c4/
This is the Most Bang For Buck mini lathe:
http://www.harborfreight.com/cpi/cta...emnumber=44859
With a 20% off coupon, you can get it for even less than $600.
If you invest a little more, you can get the MOST BFB in a larger lathe:
http://grizzly.com/products/10-x-22-...al-Lathe/G0602
CR.
Old 04-29-2009, 01:39 PM
aaron p's Avatar
Is that OTMT C4 built fairly decent?
Id really like to get a precision mathews 14x40 engine lathe, and just be done with it. Im limited to 1phase 220V in my shop.
Old 04-29-2009, 06:34 PM
IMO, it is a bit pricy. I can say it uses the same electronics/motor as my Grizzly SX3, and they have held up well for me. I have heard some good things about it:
http://www.mini-lathe.com/m4/C4/c4.htm
Just got my C4 lathe!
CR.
Old 04-29-2009, 11:56 PM
aaron p's Avatar
Do they make CNMG, DNMG, and VNMG style insert holders for these small lathes?
Old 04-30-2009, 12:16 AM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
You can find smaller shank tooling like 5/16, 3/8, and 1/2" that accommodate 80 55 and 35 degree diamond style inserts. The catch is that the inserts aren't double sided but single sided.
Look them up in MSC. They have them, but they are a bit pricey.
BTW The IC is 1/4 not 3/8 like the CNMG's DNMG, VNMG
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 04-30-2009, 12:19 AM
aaron p's Avatar
you got mail toby.
Old 04-30-2009, 12:26 AM
tobyaxis's Avatar
Moderator
You have a Reply
Toby D.
Schwarzwald
Old 04-30-2009, 09:29 PM
Teyber12's Avatar
Teyber12 is on a distinguished road
CR.
the HF 8x12 lathe is actually $450 on sale right now then you can do 20% off on top of that. I bought one about a hour and a half ago for $360 I recommend you do the same. just go up to the counter and ask if there is a sale on the 8x12. Caleb (has the x3 thread) told me about this.
cheers!
Old 04-30-2009, 09:45 PM
aaron p's Avatar
where can I get the 20% off coupon?
  #11   Ban this user!
Old 04-30-2009, 09:46 PM
Teyber12's Avatar
http://www.harborfreightusa.com/usa/...9&keycode=0000
i printed this out they just scanned the printed peice of paper and all was good
  #12   Ban this user!
Old 04-30-2009, 10:27 PM
aaron p's Avatar
I checked the harbor freight website and it shows that lathe at $600. Did your local store have a special or was it something else?? Ill buy it for $360. Thats cheap enough for me to make round spacers.
Converting my Engine Lathe to an 8-Station Turret Lathe! widgitmaster General Metal Working Machines 93 10-31-2011 04:27 AM
Synthesizing a CNC Taig Lathe from parts rather than converting a Lathe kit. eternalsquire Taig Mills & Lathes 3 04-18-2009 01:27 PM
Need Help!- Lathe spindle speed and lathe facilities GuntisK TurboCNC 4 10-26-2008 06:22 PM
New Machine Build- My CNC mill with mini lathe performing CNC lathe operations ryansuperbee General Metal Working Machines 7 08-20-2008 02:06 AM
Anyone have a mini cnc lathe or medium sized cnc lathe nymachinist Mini Lathe 6 01-23-2006 09:36 PM
