Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 04-23-2009, 04:04 PM
chucketn is on a distinguished road
KBIC-120 help
A friend bought a KBIC-120 controller to use with a treadmill motor on his lathe. He hooked it up per the manual, but it blows the AC fuse immediatly at turn on. Loud pop. I have the controller on my bench. I have checked his hook up and it was correct. He has the correct fuse, and correct power resistor for 1 hp motor. motor is a PM type.
Anyone have experience troubleshooting KBIC SCR controllers? Help! at this point, with all connections removed except the ac in and the fuse, it still blows fuses. Help please!
Chuck in E. TN
Old 04-24-2009, 03:50 PM
chalky is on a distinguished road
Is the type of fuse as well as its rating correct? You may need a slow blow rather than a quick blow fuse.
Old 04-25-2009, 06:20 AM
KBIC 120 problems
The fuse in the AC line is as recommended by KB. The fuse blows with a loud pop indicating to me that a dead short exists, w/o the motor even hooked up.
I downloaded KB's checklist for troublshooting and all resistance checks fail. I emailed KB asking for a parts diagram so I could try replacing the diodes called out by the Troubleshooting guide, and they don't supply one. They also said by my description the controller was hosed.
Chuck in E. TN
Old 04-25-2009, 02:11 PM
You could try removing MOV1 and C23 temporarily and then reconnecting the KBIC to 110Vac. If it doesn't blow the fuse when you do this then replace MOV1 ( V275LA20A ) and C23 ( 0.047uF 250Vac ) with new parts. You could also try replacing D13 and D14 with new parts ( sorry don't have type numbers for these ). Capacitors and MOVs across the ac mains live and neutral are more likely to fail in the US than in Europe because you have more thunderstorm induced surges. If your KBIC is a different revision to mine the parts numbers may be different but you should be able to locate the corresponding devices fairly easily. If you aren't confident about messing with the KBIC then junk it and buy a new one - they aren't very expensive.
Old 05-08-2009, 01:42 AM
Isplat is on a distinguished road
Hi There,
I just fixed two KBIC-120s. One had been overvoltaged to the point some traces on the back were "opened" by melting. The other one looked to me like it had been hit by lightning or a very high voltage spike.
In the later KBIC's case I found that at least one of the SCR's was blown. The MOV mentioned above was also damaged. I had to remove the MOV and both SCRs to find the one blown.
A simple check you could make is to OHM out the two AC inputs L1 and L2 -- they should not have continuity. If there is continuity the board has been damaged. In the blown board above I could use my OHM meter's continuity check (beeps) to check this.
From the symptom you described, I would guess some of the components are blown.
I haven't found a replacement SCR part number for the A69154 (Teccor) SCR on the KBIC. I believe Little-Fuse bought out Teccor. Digikey has a "case isolated" SCR that looks like a fit but I'm still trying to find an old datasheet so I can confirm the power rating needed. Don't want to put one in that has too small or too large a power rating as either can be a problem.
I'm not sure what function the MOV has in KB's circuit (over voltage?/Lightning suppression/Noise Suppresion -- I'm not positive) I haven't personnally looked up the MOV's replacement -- I trust the value above is correct. I was able to use a MOV off of another KBIC I am troubleshooting for the time being.
If I find the right datasheet I'll post an equivilent current SCR. The Diodes are also candidates for trouble (The SCRs and Diodes i'm referring to are mounted in the vertical against the metal backplate). You could use a multimeter with diode check to see if any of the were blown.
As another option, you can find them on Ebay for $20-$40 pretty regularly. So if you aren't an electronics type it might be less frustating to just try a different KBIC as your friends sounds damaged.
Old 05-08-2009, 07:26 AM
The MOVs are there to prevent spikes on the ac mains from damaging the KBIC drive circuitry and also to keep spikes generated by the KBIC from feeding back into the ac mains. The part number I gave for the MOV was for the 240Vac version of the KBIC. The 275 in the part number stands for the voltage and the 20A is related to the current rating. In the US you could use a V130LA20A. The V275LA20A wouldn't cause any problems but would let through spikes between 130 and 275V which the V130LA20A would catch. Having said all that I doubt if it matters which MOV you fit. MOVs don't last for ever and they fail short circuit.
Old 05-08-2009, 07:39 AM
Just let me clarify the statement I made in my previous post. You can use MOVs with either of the part numbers I mentioned, NOT just any old MOV .
Old 11-02-2010, 12:19 PM
kwispykweems2 is on a distinguished road
I was able to locate a replacement SCR for these guys, since mine had shorted and blown a trace and the 47ohm resistors. Called up Littelfuse/Teccor they gave me great info, and ordered from Digikey this: S6010L. This replaces the special part number used between Teccor and KB Elec, A69104. The tech support guy knew exactly what I was repairing when I gave him that number! I also have speed controllers that use A69154, and since I didn't ask about these, I don't know if the replacement will work, but I assume so since the replacement, S6010L is rated at 600V 10A and has isolated tabs, well beyond the working range of either controllers.
Old 11-02-2010, 01:58 PM
Al_The_Man's Avatar
What I have done in the past is to replace the bridge with high rating stud mount type on their own heatsink.
2 SCR's 3 rectifiers, one of which is the reverse emf diode.
Old 11-04-2010, 09:24 AM
DICKEYBIRD is on a distinguished road
Interesting & informative thread, thanks! I have 1 KBIC-120 running the spindle motor in my little Denford Micromill and another one I got off eBay to run a treadmill motor for an add-on lathe spindle. I have a couple of questions for ye KB enlightened folks.
KB's spec sheet shows 1 hp. max for the -120 with a heatsink. I don't have their "official" heatsink but am going to add the one I got off the scrapped treadmill's dead MC-70 control and a muffin fan to cool it. My motor has "2.5 hp" on the label. I figure that's probably a very optimistic rating but am concerned about the 120 being able to handle it.
The usage and duty cycle will be pretty light. I'm going to mount a lathe toolholder on the left end of the Micromill's table and use its X/Y movements for lathe ops. I'm building an ER-32 spindle powered by the treadmill motor and will mount it on the left side of the Micromill enclosure. I will be making fairly light cuts at around 1500-2000 rpm on 3/4" aluminum rod. I figure a 2.5 or 3:1 stepdown pulley will be about right. Does the KB control care about the different motors armature winding resistance it "sees" or will it just grunt out it's designed power rating and the motor never outputs its maximum potential? I can't see me ever needing anywhere near the available power from the motor. Ya'll think the -120 will be reasonably happy given the usage I've laid out?
Last question (for Al): Could you translate this to a 6th grade level please?
"What I have done in the past is to replace the bridge with high rating stud mount type on their own heatsink.
2 SCR's 3 rectifiers, one of which is the reverse emf diode."
Are you saying you replaced the KB components with generics and installed them in a separate location with their own heatsink? I may need this someday...got any pics or a schematic?
Milton
Old 11-04-2010, 04:35 PM
Al_The_Man's Avatar
Milton
Yes.
I posted some details here on an old post, I will see if I can dig it up.
C11G BOB and KBIC controller xkbal General Electronics Discussion 3 10-23-2007 09:49 AM
