Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 04-22-2009, 06:43 PM
afaiello is on a distinguished road
D&M 5 Lathe setup
We just pulled out our old D&M 5 lathe and the IBM AT computer that ran it in our tech department. However, nothing is connected. I have a serial com and a parallel port on the IBM and I see there are 3 different ports on the lathe-computer interface, solenoid driver, and some other port under the solenoid port. Yes I know I need the software. I do have rogers tool works on it, but that doesn't seem to help. How do I connect the lathe to get it running off of the IBM?
Tags
d&m, d&m5, labvolt, lathe
CNC Lathe setup mroy0404 Mazak, Mitsubishi, Mazatrol 4 04-24-2011 10:44 AM
Need Help!- Lathe Setup Guru's in Albuquerque wdp67 General Metal Working Machines 1 02-02-2008 01:23 AM
Mastercam X Lathe setup Davidimurray Mastercam 2 01-27-2007 04:29 PM
Old lathe spindle setup PIngels General Metal Working Machines 14 12-06-2006 11:15 AM
