Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 04-20-2009, 08:37 PM
curtb is on a distinguished road
HELP! DeskCNC X-axis doesn't respond.
I am setting up a Sherline CNC lathe from IMService with DeskCNC controller. The z-axis is working perfectly, but the x-axis does not respond at all. When I checked the voltage on the controller, there is no voltage between Xstep or Xdir to ground. I temporarily connected the Y axis and it worked perfectly too. The voltage on the Z and Y axis pins on the controller are the same, but I don't recall what it is. I don't know if it matters, but when I connect the controller to the servo driver, xstp stays at 5v and doesn't change ever. Any help is more than appreciated. I find is hard to believe the board is bad.
Old 04-21-2009, 08:54 AM
Gold Member
imserv is on a distinguished road
Post to the IMService private user support forum. We can help you troubleshoot setup problems at that location.
Fred Smith - IMService
http://www.imsrv.com
Old 04-21-2009, 09:09 AM
Thanks Fred. I have my request in to be setup for the forum, I'll post as soon as that's complete.
Tags
controller, deskcnc, sherline, x-axis
Grinding Cam profiles on a DeskCNC 4 axis mill Paraprop Carken Products (Deskam, DeskCNC etc) 37 05-01-2009 10:58 AM
test plug rs232 port not respond joseponzo Fadal 6 10-16-2007 02:23 PM
Sporadic Failure to Respond IQChallenged Machines running Mach Software 0 06-27-2007 10:48 PM
Fadal 904-1 does not respond to inputs tigerinnovation Fadal 1 01-22-2007 06:26 PM
Does xylotex ever respond to email? JohnG Xylotex 11 11-04-2006 04:31 PM
