Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 04-16-2009, 12:02 AM
Cartierusm is on a distinguished road
CNC 9x20 Conversion
I have a couple of questions regarding the conversion of my HF 9x20, I've read other posts but have some basic questions. Hope ya'll can help.
First off I'm using some old 1/2-5 2 start precison McMaster Carr Acme Lead Screws and Dumpster CNC Anti backlash nuts for the two axis'. So for the conversion, it's fairly straightforward, right? I mean just make some brackets to hold some angular contact bearings on one end, a floater bearing on the other and the the nut to tie into each axis. Then hook up an encoder to the spindle so mach can keep time and do threading operations? Setup Mach and you're done, right? It just seems so basic compared to converting a mill.
Now a couple of basic lathe operation questions. If I'm parting a piece and the piece is let's say 2" in diameter, I can't have my parting tool which is like 3/32" thick sticking out that much because it will chattter? So when doing a deep parting operation do I program in a stop and readjust the tool length, or does the parting blade stick out as far as I need from the beginning?
If I don't mind changing belts for different spindle speeds then I don't need to do anything else besides add the spindle sensor for doing CNC threading operations?
When setting up a part in a CNC lathe how do you determine where the tool zero is, do you measure the part exactly then use feelers to touch the tool to the non-moving part, zero out mach and then offset by the amount of the feeler? I'm cluless on how to program CNC lathes so far, so my questions are basic.
Old 04-16-2009, 03:56 PM
acondit's Avatar
acondit is on a distinguished road
I would suggest that you want a finer thread pitch unless you are using servo motors with about 1000cpr or better resolution. Unlike a router or a mill, typically you are wanting very precise control of the x-axis, and moving 0.001 is going to take 0.002 off of the diameter. Also, I tried a delrin (acetal) nut for the x-axis and it was too flexible for good accuracy. My z-axis is 5tpi and I am running 1/2 step mode. So that gives me 0.0005 per step with reasonably good repeatability of 0.001. For my x-axis I am running 10tpi with 4:1 gearing and 1/2 step. This is theoretically 0.0000625" per step, but, it is still difficult to maintain much better than 0.0005" (0.001" diameter) repeatability.
So, you really need to think about what you are trying to achieve before deciding what kind of screws to use.
Alan
http://www.alansmachineworks.com
Old 04-16-2009, 07:19 PM
Thanks. I'm going to be using 495 oz/in steppers with 72VDC at 2000 steps per rev. so a resolution of .0001. Plenty of power and I already have the screws so I'll try them and see how they work and if I get errors then I'll switch to ballscrews.
Old 04-17-2009, 11:04 AM
acondit's Avatar
If you're talking about microsteps as part of your count, you really can't rely on the position of the microsteps when it comes to holding position for a turning cut. You need to base your repeatabliity on full step positions.
On the x-axis I am using 200 oz/in steppers with 4:1 reduction gearing or the equivalent of 800 oz/in to the screw with a 10tpi precision acme screw running a cast-iron nut.
Good luck,
Alan
Old 04-17-2009, 02:46 PM
I understand what you're saying but it seems like everyone uses microsteps in lathes, routers and mills. I find it hard to believe that all these people are wrong. There is even a company selling their machine just like the way I'm going to do it. http://www.d3cnc.com/. Again I'm not trying to argue with you just stating some facts trying to figure out what the correct solution is.
Old 04-17-2009, 03:22 PM
acondit's Avatar
1/2x5 - 2 start is effectively 2.5tpi. D3CNC is using .200 pitch ballscrews (or 5tpi). Twice as fine as what you are suggesting.
I stand by my earlier comment, you need to define your goals before proceeding. If the goal is just to have a lathe the "runs under CNC control", you can accomplish that. If your goal is some certain degree of precision, then you need to design for that (remembering of course that our 9x20 machines will never be a Hardinge).
Regarding microstepping, search for information on repeatability, accuracy and microstepping and look for comments by Mariss Freimanis of Gecko fame.
Alan
Old 04-17-2009, 04:55 PM
Thanks I'll check it out.
I was mistaken my screws are 1/2-10 5 TPI so they're the same.
Old 04-19-2009, 09:45 PM
Acondit, what program do I use to make the gcode for cnc lathe? I use Rhino for most of my regular mill cad work and rhinocam, but have no clue what to use to program the lathe? Thanks.
Old 04-20-2009, 07:50 PM
acondit's Avatar
I hand write most of my code, so I can't really help you with that.
All you need to do is draw 1/2 of the profile that you want, and generate the gcode for that profile.
Alan
Old 04-20-2009, 08:06 PM
jhowelb is an unknown quantity at this point
If you are using Mach 3 there is a wizard included for most any basic shape you would want and a threading wizard for inside and outside threads.
There is Lazy Turn in progress but still not complete yet.
http://www.machsupport.com/forum/ind...topic=5767.new
  #11   Ban this user!
Old 04-20-2009, 08:28 PM
Acondit, what do you mean by draw half of it and then generate Gcode from that? I take it you mean draw half of it either vector or in a CAD program? Then what do I use to generate the Gcode?
Jhowelb, I've started to look at the mach built in wizards, how would I string a whole bunch together to make a complex piece? Would I just do each opertion separately and then cut and paste the posted codes together?
Thanks for the help. I've finally found a program Dolphin Parmaster Lathe and I've got a RFQ in for the hobbier so we'll see how expensive it is.
  #12   Ban this user!
Old 04-20-2009, 11:59 PM
acondit's Avatar
Think about looking down from the top of a finished piece. If you were to cut longitudinally along the center of the z-axis, you would have 1/2 of the finished piece. Then rotate the piece 90 degrees and lay it on the flat surface, and take an infinitesimally small slice the same direction as the first cut (but on piece rotated 90 degrees). You are left with a theoretical 2d slice that has a straight edge at the centerline of the z-axis and the profile of the cuts made by the cutting tool. Program to cut out that profile with X and Z moves, remembering that the part is hidden in your starting stock so by repeated cuts you have to uncover the hidden part.
You said that you currently use Rhino, how do you generate gcode from that? I started off drawing the parts, exporting a DXF and then using NCPlot do create gcode from the DXF. Eventually I had created enough sub routines that it became faster to write the gcode by calling my own subroutines.
Without showing all of the subroutines that I have written, this is what the code looks like to cut this part:
o230 call [1] [500] ( Change to tool 1 Facing & turning )
o500 call [0.650] [0.010] [-0.0625] [0.000] ( Face off end )
o130 call [0.630] [0.00] [0.375] [0.750] ( Turn end to 3/8 for spider )
o130 call [0.630] [0.75] [0.500] [1.500] ( Turn bearing surface to 1/2 )
o130 call [0.650] [2.25] [0.610] [0.500] ( Turn body to just under 5/8 )
o230 call [6] [800] ( Change to tool 6 threading )
o120 call [0.500] [0.700] [0.550] [0.4987] [0.050] ( Thread for bearing preload nut )
o230 call [9] [400] ( Change to tool 9 parting )
o240 call [0.650] [2.75] [0] ( Part of ballscrew end )
However, I use EMC2 rather than Mach.
Alan
ID:	80061   Click image for larger version
9x20 Lathe Conversion dareposte Mini Lathe 71 11-16-2011 04:34 PM
CNCFusion 9x20 lathe conversion? thumper650 Mini Lathe 17 04-24-2007 02:00 AM
Cad files for 9x20 cut more Mini Lathe 0 02-02-2007 07:25 AM
1/2 HP vfd conversion for 9x20 Runner4404spd Mini Lathe 16 01-31-2007 01:26 PM
need complete cnc conversion for 9x20 or 9x30 sidoiler General Metal Working Machines 2 09-11-2006 12:32 PM
