| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
When I first learned of expanding mandrels (and saw some low resolution pictures), I incorrectly assumed that there must be some inherent mechanical means of drawing the sleeve over the arbor to expand it. So just sliding the sleeve over the arbor by hand expands the sleeve and generally grips the work with enough force to machine it without easily coming loose? Sorry if this is a stupid question. |
| Hi Marcel, Thanks for the reply. Let me see if I understand your recommendation: I should always cut toward the larger end of the tapered body (i.e., mandrel), which would be towards the headstock? Is that right? Also, since I can't seem to find the proper size lathe dogs for my setup, I'm thinking about using some cheap set-screw type shaft collars, with the short set-screw replaced by a longer screw which is driven by a bolt mounted in one of the slots on the faceplate. Does that seem workable? Lastly, I just got a set of five expanding mandrels, supposedly covering the range of 1/2" to 1"; and the diameters of the drive ends of the mandrels all correspond to "standard" shaft sizes, except for one mandrel, which is 21/32" diameter. So here's my question: If the shaft collar idea will work, should I bore out a 5/8" shaft collar to 21/32", or would 0.03" of clearance on the diameter be ok, allowing me to use an 11/16" shaft collar for the 21/32" mandrel? Thanks. Regards, Nelson |
| Hello Nelson Yes the collar would work , yes alway's work toward the larger end of the taper taking small cuts. if the mandrel expands to the size you need it should hold your part , remember you must force your part on the mandrel usually i hold the mandrel and the bushing holding the part and just tap it on a wood bench to hold everything together Marcel |
| Do you think a shaft collar with an ID of 11/16 (0.6875) inches would have too much slop to work as a lathe dog for a mandrel with a diameter of about 0.653 inches, or would it be ok? Also, do you think aluminnum shaft collars would be ok, or would you go with steel? Thanks. Regards, Nelson |
| Need Help!- New guy here - Best type of drill bit for expanding (boring) a hole in brass? | Jr Gearhead | General Metalwork Discussion | 2 | 12-12-2008 12:37 PM |
| Newbie- Work Planes / Work Coordinates | MICFDI | Esprit | 9 | 05-12-2008 12:35 AM |
| Great Stuff expanding insulation for lost foam molds? | WayneHill | Moldmaking | 8 | 06-01-2006 06:19 AM |
| Expanding foam beads | TinkerDJ | Moldmaking | 4 | 04-29-2005 02:48 AM |
| expanding lpt port | scott m | General Electronics Discussion | 5 | 11-30-2004 08:33 PM |
