| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
Hello forum, I'm new to this forum, and just bought my first lathe - a Weiss WM180V. Link: http://www.weiss.com.cn/products/wm180v.php I have worked a bit with lathes before in school some years ago. I have read through the manual, and there are expressions I don't find familiar, and need an explanation for. The manual is english, and my native language is danish. Here we go: The manual says: "Clean all components of the end gear assembly and coat all gears with heavy, non-slinging grease." What is non-slinging? In the lubrication section of the manual, it says "Lubricate the change gears and the leadscrew with a lithium-based grease." So I need a "heavy lithium non-slinging grease" for all the gears and the leadscrew or should I apply different kind of grease for the non-changeable gears and the change gears/leadscrew? I would guess that "heavy non-slinging grease" is a thick, non-fluid-like grease that creates "hair-strains" between the rotating gears. Am I right? Since the lathe is manufactured in China, it's kind of dirty. Would I be doing something wrong in disassemble the lathe and clean contact surfaces (with diesel fuel/kerosene as the manual recommends) and then re-lube the surfaces with the recommended "20W machine oil"? The lathe will be stored inside the house and moved outside or to a workshop when used. Hmm, that's about the questions I've got right now. I just figured out what "taper" was when looking through the manual again :-) I'm sure more questions will come when I start using the lathe. But I also have a forum in my native language for that kind of help. Thanks. Best regards, Futterama |
| This is a good site for getting started with your mini-lathe. Yours looks slightly different than the typical Sieg 7x12 but the same procedures should apply. http://www.mini-lathe.com/Mini_lathe/Start/start.htm Most people use regular white lithium grease like you find in any hardware store. I use it only on the concealed parts that don't see light very often. Everything else gets motor oil. |
| Converting my Engine Lathe to an 8-Station Turret Lathe! | widgitmaster | General Metal Working Machines | 93 | 10-31-2011 04:27 AM |
| Need Help!- Lathe spindle speed and lathe facilities | GuntisK | TurboCNC | 4 | 10-26-2008 06:22 PM |
| New Machine Build- My CNC mill with mini lathe performing CNC lathe operations | ryansuperbee | General Metal Working Machines | 7 | 08-20-2008 02:06 AM |
| How to convert Manual Lathe to CNC Lathe? | zaid | General Metal Working Machines | 4 | 02-07-2008 01:42 AM |
| Anyone have a mini cnc lathe or medium sized cnc lathe | nymachinist | Mini Lathe | 6 | 01-23-2006 09:36 PM |
