| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
Is there a way to modify the spindle on a 7x lathe to over 1 inch? Or a replacement spindle with a through hole about that size? And what is the biggest usable chuck one can put on the 7x? I see there are 4", 5", and 6" options. I imagine the 6" might be a little big; the jaws may hit the bed? Rich |
| I bored my spindle out with a boring bar to 7/8". I think 1 inch would be pushing it. If you have a look at the output gear on the spindle for the gear change you will find it is not much larger if at all than 1 ". I also put a 5 inch chuck on which I love. Gives the lathe a smoother operation I feel due to the additional rotational mass. Kurt |
| One inch would be bad. The OD of the spindle is only 30MM (1.18") Frank Hoose of www.mini-lathe.com reports the 5" chucks fit.
__________________ Mike N No good deed goes unpunished. |
| Thanks for the report Gary. My 4" is just an ultra fine hair too small to grip a small crankshaft from a weed whacker motor. I may end up having to get a 5" chuck.... Yay! More money!
| Definately sounds like something I should know about! |
| spindle hole, collet and chuck maintenance | taydin | Benchtop Machines | 1 | 09-13-2008 09:53 PM |
| Newbie- Attach lathe chuck on X2 spindle | leandrot | Benchtop Machines | 3 | 08-09-2008 07:32 PM |
| How can I mount a chuck in my mill spindle? | cnczoner | General Metalwork Discussion | 6 | 03-09-2008 08:34 PM |
| Spindle Chuck Questions | SPEEDRE | DIY-CNC Router Table Machines | 5 | 01-19-2008 01:28 AM |
| How do I remove a kwik chuck/spindle | Andyh | Bridgeport and Hardinge Mills | 1 | 08-14-2005 01:28 PM |
