Results 1 to 4 of 4
Thread: How big a piece (diameter) can a 7x lathe turn?
    Sep 2008
    U.S.
    When I retract the cross slide on my Microlux lathe all the way back, it looks like the front face of the tool holder is only about 1.75" or so away from the center line, which to me implies that the largest diameter piece I can turn down is in the range of 3" to maybe 3.25" or so, depending on how the tool bit is mounted.
    Yet from what I read at www.mini-lathe.com and www.littlemachineshop.com, it seems that four and five inch chucks are quite popular...so my question is: Why would anyone want to put anything bigger than a 4" 3-jaw, or a 3" 4-jaw chuck on a 7x lathe? Is there a way to turn diameters bigger than 3"?
    Registered TacPyro's Avatar
    Feb 2009
    The largest part that I have turned on my Microlux 7x14 was 3" and it was tight. I'm not sure if you could turn much bigger than that.
    -Blane Nelson
    www.tacticalpyrotechnics.com
    Feb 2008
    UK
    You may not turn outer dia's greater than 3 - 3.5" it doesn't preclude the turning of larger objects for boring / facing operations! They are small machines - probably stall on stuff much larger anyway! Should have got a larger machine..................old adage - 'easier to turn small stuff on a big machine than big stuff on small'
    Sep 2008
    U.S.
    Hello TacPyro,
    Thanks for your reply.
    Apparently you can turn larger diameters, e.g., 4", as long as they are relatively short pieces, e.g., 1" - 2" long...the bigger in diameter, the shorter they must be.
    I guess you would do this by loosening the compound slide and rotating it away from the axis, and then rotate the tool post to make the tool perpendicular to the work again.
    This is what I've been told.
  1. Need Help!- In Bobcad 21, how do I draw up a lathe piece
    By seanreit in forum BobCad-Cam
    Last Post: 06-30-2008, 12:32 PM
  2. Replies: 3
    Last Post: 12-23-2006, 10:41 PM
  3. RFQ: Lathe work, one piece.
    By SCCoupe in forum Employment Opportunity
    Last Post: 07-24-2006, 06:58 AM
  4. RFQ for Two Piece Lathe & Mill Work
    By stang5197 in forum Employment Opportunity
    Last Post: 02-20-2006, 10:17 PM
  5. RFQ Custom Lathe Piece
    By Cold Fusion in forum Employment Opportunity
    Last Post: 04-05-2005, 01:09 AM
