Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 02-23-2009, 12:09 PM
TroyO is on a distinguished road
Indexable tools.. what applications?
I got the Littlemachineshop tooling set for the 8-12 with the indexable toolholders. The description is this:
The set of indexable turning tools includes 5 tools (TAR, TAL, TBR, TBL, TE), inserts, a wrench, and extra screws.
I get that you want the sweep to be away from the cut and that has worked well.
Which one do you use for facing operations? Does it just follow the same rules.. sweep away from the cutting direction? Is there another tool I should be using entirely?
Also... any reason you can't use the straight-on holder for threading purposes? (Assuming you use a pointed insert without a rounded nose.)
Last dumb question... I see that the sweep angles have one that ends at *90, I can see where that would leave a nice shoulder. Is there any advatage to useing the one that goes past *90 for other operations?
Old 02-23-2009, 09:26 PM
escott76 is on a distinguished road
I use the left hand tool for facing.
You certainly don't need a "pointed" tool with no radius to cut threads. Have a look at thread form specs, you'll see there are allowances for the bottom of the thread. Sharp pointed tools take more work to cut, and dull quicker.
Job Opening Applications Engineer Philm Employment Opportunity 13 04-16-2008 08:37 PM
CNC for medical applications mfahad016 General Metal Working Machines 5 10-27-2006 03:49 PM
Mach 3 capabilities & applications howling60 Mach Software (ArtSoft software) 6 03-08-2006 07:28 PM
g-rex commercial applications available? h_2_o G-REX 0 02-05-2006 03:49 AM
EDM Applications Engineers Needed kimb Employment Opportunity 0 10-06-2005 12:28 PM
