Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 02-03-2009, 08:47 AM
dirtmover is on a distinguished road
Mini lathe leadscrew alignment problem
I have a generic (SIEG) mini lathe from Priincess Auto. The carriage starts to get stiff as it approaches the headstock. I've lived with this for a while but I've just started to use the feed for thread turning and it is causing problems with the direction selector kicking out especially with coarse threads due to extreme friction.
After some experimenting I realised that the cause of this is the backing support for the half nut pushing down hard on the leadscrew at the head end, it's fine at the tail end. This leads me to believe that the screw is not parallel to the ways and needs to be lowered at the headstock end.
Now, simply lowering the pillow block at the head end introduces other issues with the gear adjuster which would also need to be lowered. The other option would be to raise half nut but I'm not sure if this is even possible? Of course this would also require raising the pillow block at the tail end which should be much easier to achieve.
Has anyone else experienced this issue with these lathes and if so what is the solution?
Old 02-09-2009, 06:48 AM
To answer my own question and for the record I resolved this yesterday. There is no adjustment possible for the half nut. I elongated the holes in the pillow block at the head end to allow it to move down about 1.25mm and shimmed out the blocks at both ends so that the gear adjuster is not impacted. The apron was also moved out by the same amount so that the half nut is properly centered. The lead screw turns better than ever now with minimal friction regardless of the carriage position.
Old 02-09-2009, 07:29 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Well done dirtmover! Good Job!
CR.
Mini-Lathe Tailstock Chuck Alignment bowentw Mini Lathe 13 12-06-2006 02:24 PM
Q: Mini lathe Tailstock Alignment? Deviant Mini Lathe 5 08-19-2006 07:25 PM
ACME Leadscrew Acetal/Delrin and Ballscrew Kits and Plans for the Sieg X2 Mini-Mill fignoggle Product Announcements & Manufacturer News 0 04-21-2006 08:36 PM
build help on alignment of leadscrew, rails etc posix DIY-CNC Router Table Machines 1 02-10-2006 02:14 PM
Mini Mill alignment tpicker1 Benchtop Machines 5 05-12-2004 04:36 PM
