| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
Im looking for any advice on a belt and pulley system for my mini lathe,I am building my own spindle and I want it to run about 12,000 rpms.I already have the lathe built but the spindle I have now will only handle about 5000 rpms so Im building a new one and dont know what belt and pulleys will handle these high rpms? Any advice would really be appreciated! Thanks Mike Last edited by CATCH22; 01-27-2009 at 10:06 PM. |
| That makes sense. FWIW, there are easier ways to do that than trying to spin the lathe spindle so fast, which is pretty hard. The usual approach would be to build a holder for an air spindle (or a motorized electrical spindle) that sits on your cross slide. You can then use CNC control to position the spindle on axis and drill your tiny hole. Those little spindles are pretty cheap because they don't have to be so heavy duty as the full lathe spindle would need to be. This is also a more versatile arrangement since you can drill holes parallel to the spindle axis that are off axis. Would that work for you? Cheers, BW |
| Belt and pulley | xshaper | Foam Cutting Software | 5 | 09-20-2008 06:46 PM |
| Need Help!- SX3 high speed pulley ??? | cjdavis618 | Benchtop Machines | 13 | 07-03-2008 01:10 PM |
| HTD timing belt pulley | R.thayer | General CAM Discussion | 1 | 02-03-2007 12:42 AM |
| RFQ V-Belt Pulley | vadimvc | Employment Opportunity | 0 | 07-14-2006 01:10 AM |
| high speed positioner..timing belt? | KTP | Linear and Rotary Motion | 1 | 02-19-2006 10:24 PM |
