| Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here. |
Has anyone converted there HF 7X10 to 7X14 using the little machine shop kit? If so is there any tricks or good advise one can pass along. It does not look very hard to do, just looking for any input. Thanks in advance. Mike |
| I found this place recently... http://gunhead.com/GMW/index.html You meant bed conversion... Never mind. |
| The swap is very easy to do. But the thing to consider is that each bed and headstock are matched and worked on to match at the factory. You may have an alignment issue afterwards. But some shims will do the trick. Good luck. Richard |
| The swap was easy. The whole project has taken about five hours. Drilled and tapped extra holes for the lead screw cover, control box and missing chip guard hole. Does any know where I can get a longer chip guard and lead screw cover? Or is that something I have to make my self. I am very happy with the conversion. |
| You can find the longer chip pan & leadscrew cover at www.LittleMachineShop.com |
| Need Help!- 7x10 ballscrew - mini lathe cnc conversion | tbilalis | Mini Lathe | 3 | 03-22-2009 10:15 PM |
| Newbie- HF 8x12 vs HF 7x12 vs. Micromark 7x14 | andrew_h | Mini Lathe | 9 | 02-05-2009 12:21 PM |
| HF 7x10 to 7x19 bed conversion | KOS | Mini Lathe | 8 | 12-09-2008 11:05 AM |
| New Micromark 7x14 - First Impressions and a Question | HankB | Mini Lathe | 3 | 02-03-2008 12:51 PM |
| Take yer 7x10 to 7x14 with LMS upgrade kit | rashid11 | General Metal Working Machines | 0 | 07-07-2005 08:33 PM |
