Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 01-11-2009, 09:22 PM
twocik is on a distinguished road
Pulling this off ?
I need advice on how to pull this off.
I'm making threaded 15mm/0.590" rods. The rods will have a female and male thread ends. I've bought 15.875mm/0.625" solid stainless rods and plan to sand them down to 15mm. I'm running a 9 x 20 HF Lathe and own pre-ground internal & external 55° HSS threading tools.
Any advice on sanding or threading stainless steel please feel free....
Old 01-12-2009, 04:07 AM
TOTALLYRC is on a distinguished road
For what it is worth, you need to remove .035", by "sanding"? I would turn them to within a thou or so, and then sand to final size if the final od is that critical. With the right cutter, they should cut pretty well, unless you have a weird alloy or something.
"we" need more information such as tolerances, type and harness of material, and any other info that you can think of.
Mike
Old 01-12-2009, 05:58 AM
As for tolerance, it's going into a clamping system, so it can be a little over 15mm. The material is solid 316 stainless steel.
15mm OD x 475mm L
Old 01-12-2009, 09:32 AM
alflipo's Avatar
alflipo is on a distinguished road
Removing .034" by sanding alone is not realistic, machine the pieces in between centers first, and I would use a tap for the internal threads.
"55° HSS threading tools"... are you using the Whitworth thread system?
Old 01-12-2009, 02:46 PM
""55° HSS threading tools"... are you using the Whitworth thread system?"
Don't have a clue what that is, basically two pre-ground internal & external lathe tools. I bought them from grizzly about 1 year ago.
Old 01-12-2009, 10:20 PM
hndswthtshdws is on a distinguished road
The Whitworth system is an old British thread standard. 55 degree angles, a thread depth of .640*pitch, and a diameter of .137*pitch. Unless specified you should probably be using a standard 60 degree thread.
You will probably have more luck with a taper and plug tap for the inside threads than using the single point threading method. The outside threads are your call, I myself prefer a die for short sections of thread.
Old 01-13-2009, 10:32 PM
Yes I'm starting to think the same, I'm not sure my internal thread tool will even fit. So I think I might be using a tap, but I've never used one on a Lathe. As for a die, I'd say I need a 10mm - 12mm die, again never used one on a lathe.
I've used the IN. & EX. thread tools before, so I felt a little more comfortable with them. Any tutorials on how to set the tap & die on a lathe ?
Old 01-14-2009, 05:27 AM
Build something like this to keep the taps and dies aligned:
http://www.gadgetbuilder.com/DieHolder.html
http://www.homemetalshopclub.org/pro.../lathetap.html
I usually turn those tools by hand to cut the thread. Its too easy to break taps by power cutting.
Old 01-16-2009, 08:46 PM
Runner4404spd is on a distinguished road
the real question is how many do you have to make. if its just the pair then thats easy. if its a few thousand then i would send them out.
1. is the material 304 or 316? can you use 303? if you can use 303 do it.
2. get some heavy thread cutting oil
3. get some cobalt drills in the right size along with a tap and die for your thread
4. like mentioned before drill each side to the right size, thread one end with the die and tap the other end with the tap.
5. turn between centers to the final dimension. skip sanding.
Old 01-19-2009, 07:30 AM
Just one set
2 - 18" threaded (M & F)
2 - 6" threaded (M & F)
316 is the material I have. I've heard 303 is easier to machine, but wasn't sure of it's corrosion & tensile strengths. I bought some new Tin coated insert tips, and hope I'm ready to go.
  #11   Ban this user!
Old 01-23-2009, 12:17 AM
My new turning tools & boring bars arrived today and I also bought a metric tap & die. This is my first time using this style tool (insert tip turning tool) and cutting stainless steel. I can't seem to get a nice finish, and need a little bit of help. I've tried different angles, taking light cuts and can't seem to find the sweet spot. If you look closely you'll see that it is leaving a groove across the part.
Any advice or links would be greatly appreciated. Here are a few pictures of what I got
  #12   Ban this user!
Old 01-23-2009, 12:34 AM
jalessi's Avatar
jalessi is on a distinguished road
Smile
Twocik,
What is your feed rate set to?
Jeff...
New Machine Build- Pulling the pieces together solodotcom DIY-CNC Router Table Machines 6 07-08-2008 10:10 AM
pulling bar without barpuller pit202 Haas Lathes 3 06-02-2008 12:32 AM
203V Pulling my hair out!! WilliamD Gecko Drives 9 04-18-2008 01:09 AM
Mazak QT-10 Bar Pulling jbhill Machine Problems, Solutions , Wireless DNC, serial port 2 08-09-2004 07:16 AM
Is Taig pulling my leg? c131fr Taig Mills & Lathes 27 07-12-2004 04:31 AM
