I think what you're looking for is a "N" size blade, which is .040 wide. Enco has them in cobalt:
http://www.use-enco.com/CGI/INSRIT?PMAKA=308-0608
You can get insert tooling if the cobalt doesn't do the job, but if you're using a 7x lathe at that point you might consider doing your parting with a cutoff or bandsaw instead. You need a lot of rigidity to cut hardened steel and sometimes the 7x just doesn't have it.
LinkBack URL
About LinkBacks
