Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 12-19-2008, 02:44 AM
twocik is on a distinguished road
Gear slipping problem ????
I own a 9 x 20 lathe and my gear lever keeps slipping. I've found the problem and have no idea how to open it to fix the problem. I forgot the name of the part, but it holds the lead screw and has a ball insert fluid cap.
It seems to be sort of at times locked and is causing my gear lever to slip. I've removed the end nut that has a set screw thru the top of it, but the part won't come off. It's getting pretty hot when turning parts.
Any idea where I can get another or do I need to replace the whole lead screw ?
Old 12-19-2008, 06:18 AM
kawazuki is on a distinguished road
Its just called a 'bracket' in the manual! I assume with the oiling point its a plain bearing that has either got some swarf in it or its run 'dry' and the shaft has picked up on the bearing material, sort of confirmed by getting hot in operation. Its appears not to be restrained, so if unbolted from the bed casting it should come off the end of the leadscrew? Two options - ream out and install another bronze bush bearing or if big enough, bore oversize and fit a caged needle roller bearing - but lubrication is a must for whatever is fitted.
Old 12-19-2008, 02:58 PM
I've tried to get this thing off and that's a no go. Not unless I'm doing something wrong. Yes I think it's probably shot and needs to be replaced. I don't feel like waiting for another from HF and would like to just replace it.
Now if I can get it off, maybe I'll bore it out for the bearing fit.
If anyone has experience with getting this thing off, please feel free to chime in.
Newbie- Space Gear 48 serial Communication Problem stanley66 Mazak, Mitsubishi, Mazatrol 0 04-28-2008 07:38 AM
x axis slipping FUN4ME Fadal 2 01-08-2008 02:20 PM
Y Axis Slipping ?? twocik Benchtop Machines 18 12-11-2007 05:11 PM
Gear Teeth thickness problem. nikolatesla20 Mechanical Calculations/Engineering Design 3 08-09-2005 01:39 PM
Boss z-axis belt slipping jderou Bridgeport and Hardinge Mills 13 06-01-2005 01:08 PM
