Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > Benchtop Machines > Mini Lathe
Mini Lathe Discuss Sherline, Harbor freight and other Mini Lathes here.
Old 11-12-2004, 08:15 PM
Gold Member
JFettig is on a distinguished road
CNC conversion kit
Are any of you interested in a cnc conversion kit for the 7x lathes? I have partially designed one and have the idea in my head mostly. it would actually end up being a 12x or so lathe by the time Im done with it for multiple tool posts
what I need to figure out is what you guys want if I was to do this, leadscrew, basic cheap stuff or ballscrews or even preloaded ballscrews.
I went to price out ballscrews to have it preloaded, steppers, and xylotex drives and all that would come up to be about $350, then there would be the rest of the hardware, that would cost some, I am not so sure about doing one or two, its typically not worth the time to do one offs, then to get enough to do a small production run at work and keep the costs down is also difficult as there are many parts to it.
Basicly what I have designed is a new carrage and cross slide that would have about 6-8" of travel I have to decide on motor sizes and screw sizes to complete the drawing, I have whats important to fit it on the lathe designed.
This is something that I will probably not have time to get to untill summer if I end up even getting to it.
My mill isnt quite big enough to make the larger parts like the carrage and cross slide, so if I was to sell these I would have to do this part at work if we would even find time to do it.
Would there be enough interest to make like 20 of these kits up and sell them?
Basically it would replace the existing carrage and either use the existing leadscrew with a motor mounted to it and that would be the only modification to the lathe becides removing un-needed stuff.
Jon
Old 11-12-2004, 09:19 PM
kdoney is on a distinguished road
I would be interested. On mine no modification to the lathe was needed. I use the existing drive mechanics. One servo is gear belted to the leadscrew and another servo is bolted onto the cross slide. It is as accurate as the manual lathe. (The photo is before I put an acrylic cover on the gear housing and hooked up the drivers.)
Old 11-13-2004, 12:50 PM
Gold Member
That is very nice man! I was thinking about doing direct drive steppers or something similar, maybe customizable mounts. I would also be using a larger tool post, I already have the larger tool post on my lathe 1/2" tool max and its a little more rigid than the stock one it seems. I would also get rid of the compound slide or just not include it.
Did you just use the half nut for your z axis?
I was thinking I would use a regular nut or ballnuts for that one.
My design also has room for 5/8" ballscrew and possibly preloaded nuts in the cross slide.
Jon
Old 11-13-2004, 01:49 PM
RotarySMP's Avatar
RotarySMP is on a distinguished road
I did my conversion with ACME (actually the metric equivelent), and am just in the process of designing a ball screw conversion as I am not the pleased with the wear and variable backash with the current set up.
I'm using a Phase II AXA tool post on a plynthe without the compound and fina good match to the CNC conversion.
Make sure to address a swarf guard for the Z screw.
Regards,
Mark
www.wrathall.com
Old 11-13-2004, 09:42 PM
Yes I just used the half nut and lead screw. I would like to go to ballscrew on both axes. I have 2 ground screws long enough but haven't had the time. When you come up with a design, I would like to look at it.
Hey Mark, any photos?
Old 11-14-2004, 04:00 AM
RotarySMP's Avatar
http://www.wrathall.com/Interests/interests_index.htm
Regards,
Mark
www.wrathall.com
Old 11-14-2004, 11:23 AM
Gold Member
Mark, do you have any updated pictures anywhere? you said you have an enclosure and some other stuff?
Jon
Old 11-14-2004, 02:35 PM
RotarySMP's Avatar
http://www.wrathall.com/Interests/CN...Enclosure3.htm
The enclosure looks like this, but witha green tin wall.
What other stuff did you want to see Jon?
Regards,
Mark
www.wrathall.com
Old 11-16-2004, 09:29 AM
Gold Member
I was just wanting to take a look at all the stuff you did to it, Your site is kinda hard to navigate and find stuff like that. Do you have a folder with just pictures in it?
I am still trying to decide between leadscrew and ballscrew for mine.
What size stepper motors do you have on there?
Jon
Old 11-16-2004, 09:48 AM
CNCadmin's Avatar
Site Owner
CNCadmin has disabled reputation
How do you guy's handle driving the spindle? You must be able to control the speed for doing threading operations. I thought of using a encoder on the motor OR using a high speed servo motor.
Thank You,
Paul G
Site Owner-Webmaster-
Administrator
www.rfqwork.com
www.cnczone.com
www.welderzone.com
Old 11-16-2004, 10:31 AM
Gold Member
With turbocnc you can use a 1 rev encoder. At turbocncs site, they have a scematic and all for it. It woudl be better to use a regular encoder, I dont know how the screws will turn out because there will be a little bogging down and it could change a little bit. so who knows how acurate it will be, Although I have seen some threads made with it. Mach2 uses the same thing for an encoder.
So far, I am only working on designing the hardware, havent gotten to the encoder for the spindle yet.
I beleve the scematic and parts are simple and cheap and easy to get ahold of from what I remember.
When I figure out what I want to do for screws, I'll design a hard copy.
Jon
  #12   Ban this user!
Old 11-16-2004, 12:34 PM
I just use a Optek optical switch (OPB620) and a disk with one hole on the spindle in it to trigger the switch. littlemachineshop.com has a kit if you don't want to do it yourself. You would have to tape over the holes which are not needed in his kit.
Kevin
Pics of my RF45 clone cnc conversion with flood coolant CNCPlastic Knee Vertical Mills 9 01-26-2005 03:02 PM
Mini-Mill CNC conversion kit? arrio Benchtop Machines 1 12-28-2004 07:36 AM
Gorton P1-2 + Sherline CNC mill conversion. jaydee116 Vertical Mill, Lathe Project Log 2 12-12-2004 12:10 AM
First Impressions for CNC mini mill conversion CNCadmin General Metal Working Machines 4 11-16-2004 09:37 PM
CNC Retrofit - Kit verses turn on and go MetDetect General Metal Working Machines 21 07-12-2004 11:06 PM
